08 LR2 Driver's side window regulator/motor assembly replacement
Old Dec 11, 2018 | 01:17 PM
Jazon Gehrken's Avatar
Default 08 LR2 Driver's side window regulator/motor assembly replacement
I've searched high and low and found nothing anywhere so I'm slightly concerned, but I need to replace the window regulator assembly on my 2008 LR2 driver's side window. The problem is there doesn't appear to be any way to remove the old assembly from the inside of the door, or fit the new one in. Has anyone replaced this before, or have any tips or tricks before I year everything apart?
Old Dec 17, 2018 | 07:04 AM
grumsel's Avatar
Here are some tips with photo's: Window Cable Broken and: Window Lifter Driver Door
The repair manual (download here: Repair Manual, page 2249) also has a section about replacing the window motor and regulator assembly.
mattmo78
May 31, 2015 11:48 PM
zski128
Dec 10, 2014 09:46 PM
britishdiscovery
Oct 1, 2009 01:46 PM
raasaymacleod
Sep 23, 2009 12:36 AM
david1289
Mar 30, 2009 10:28 AM
