2008 3.2 Replacing Power Steering Pump. Need Advise. Pls Check Video.
Old Nov 24, 2019 | 06:58 PM
Turbo_Boss's Avatar
4th Gear
Default 2008 3.2 Replacing Power Steering Pump. Need Advise. Pls Check Video.
Hey guys,
I have a 2008 Volvo XC90 with 3.2 engine same as the one in the LR2. It has 89,000 KMS
Yesterday just at half mile from my home the steering got super heavier and there was a screaming wheezing sound. I immediately turn off the AC. I drive slowly to my house.
Thank GOD this happened late at night and there was no traffic so I will say I drive this way less than 10 minutes and only when I steer was the screaming noise.
So today I check under the hood. Open the power steering fluid reservoir and it full. Start the engine and its look like the power steering pump pulley lock/stuck itself momentary when it has to make force to steer.
So I am pretty sure the power steering pump is FUBAR. I will order an aftermarket one.
Also I see the serpentine belt got some damage because of the friction with the power steering pulley problem. I also can see in some places rubber parts of the belt so its look like I also will need to order the belt too. I will order a Continental Contitech Brand.
BTW, I will also order the O Ring kit to repair the Power Brake Booster Vacuum Pump since is leaking oil.
I have wrenched my cars before and could use a hand. Please check the video and I will really appreciated your comments or any advice on other parts you advise me to order.
Thx for your help and time
Isaac
Old Nov 25, 2019 | 06:18 PM
LR Techniker's Avatar
It seems like the belt tensioner is bad and not the pump. It looks the like squealing is the belt slipping. Its been awhile, but I think I remember doing tensioners on those.
Old Nov 25, 2019 | 07:51 PM
Turbo_Boss's Avatar
4th Gear
Hey LR Techniker,
Will check my tensioner. I am going to cross my fingers is that............ Replacing that pump is look like is a PITA
Thx for your time and help
Isaac
Old Mar 6, 2020 | 01:57 PM
Turbo_Boss's Avatar
4th Gear
Hey Guys,
Just an updated of my fix. The problem was the Belt Tensioner Pulley
Please check this post........ At the end you will find my advices and photos
https://www.freel2.com/forum/topic33363.html
Hope this info help anybody
Thx & Rgds
Isaac
MadScientist
Apr 12, 2021 09:37 PM
LICKDLISH
Mar 17, 2017 10:28 AM
Lawgirl
Jul 21, 2015 07:38 AM
ogden45
Dec 28, 2011 08:50 AM
Robeye
Mar 11, 2008 12:16 PM
