Power steering pump has play in pully
Old Mar 11, 2008 | 11:47 AM
Robeye's Avatar
6th Gear
Default Power steering pump has play in pully
Hey gang,
Thanks for the help with my belt issue over a week ago. Apparently I have found why the last belt broke. The power steering pump works, but when I put the new belt on, it jumped a bead from the PS pully. I removed the belt again and found that the PS pully has play in it. The shaft can move forward and back as much as a half inch or about 12 mm for you metric folk.
Any clue why this is happening? A retainer ring inside or bearing slipped? Any repair thoughts other than PS replacement? It's an "02" Disco II.
I caught threads on what else to replace when replacing the pump, but is this going to be a hastle to replace? Not a novice with tools for sure.
TIA
Old Mar 11, 2008 | 12:16 PM
Default RE: Power steering pump has play in pully
The was another p/s pump issue a week or so back, in his case, he had the whole shaft come out. I would say you have the same issue and your pump is probably not long for this world. Be care and keep an eye on it, if it fails, it can cause some bigger expense.
Vinndego
Jan 6, 2014 11:14 AM
xmarksit
Nov 26, 2013 08:37 AM
ColoDisco
Apr 9, 2010 11:25 AM
Evian
Aug 18, 2005 11:34 PM
kfordric
Jun 19, 2005 01:52 AM
