2008 Canadian LR2 SE block heater
Old Jan 18, 2019 | 05:35 AM
ThorInc's Avatar
Default 2008 Canadian LR2 SE block heater
I am attempting to install a block heater in a 2008 LR2 SE. This is the item I am attempting to install:Zerostart 310-0003 Engine Block Heater, 1" npt freeze plug bore
Purchased from Amazon. My difficulty is locating the/a freeze plug location to install this. I removed the engine undershield but I still can't see a freeze/frost plug location? Anyone done this and can point me to the right area of the engine block?
I also checked with my local Land Rover parts guy and he was not very knowledgeable with this procedure !
Old Jan 20, 2019 | 01:40 PM
ThorInc's Avatar
To update, I got great help from Sierrafery at landroversonly.com regarding this info. He provided this link and the part #6026 that is the freeze plug!
CYLINDER BLOCK AND PLUGS, SI6 3.2L PETROL (3.2L DOHC MPI PETROL I6) - FREELANDER 2 (C2) 2006-
Again, all credit for this helpful link goes to Sierrafery and I thought I would post it here to update this thread for any other forum members seeking this information.
Old Dec 5, 2019 | 10:35 AM
Will Warren's Avatar
How are you liking the heater? Do you keep it plugged in all night? I have a 2009 lr2 and am about to pull the trigger on this. Let me know. Thanks, Will
Old Dec 5, 2019 | 03:51 PM
ThorInc's Avatar
Believe it or not, I have not actually installed the block heater to date.......shocking, I know, but I park in the garage at the moment. I intend to install it when I proactively install a new thermostat sometime in the new year and change the coolant. You can also get one that installs in the coolant line that would likely be a much easier install in the long run..
Now, I have used a block heater in a previous vehicle for over a decade, I usually plugged it into a quality programmable timer (that can handle decent amperage) and ran it for 4-5 hours before I would usually need the vehicle.
Will update the thread once I finally get around to doing the install.
Old Jan 11, 2020 | 06:08 AM
guy's Avatar
guy
I use the LR supplied heater... plugging in just an hour before I need to head out.
Old Jan 27, 2020 | 09:06 AM
flybd5's Avatar
That link is a GREAT resource! Thanks!
AKDiscovery
Jan 28, 2026 08:55 AM
K9Hexe
Nov 17, 2023 02:35 PM
Kflex
Jan 19, 2016 08:14 PM
danie68
LR2
Aug 18, 2015 09:47 PM
dalbrecht
Dec 4, 2010 09:30 PM
