2008 Land Rover No Start p0365 p0340
Old Mar 10, 2025 | 04:52 PM
  #21
flybd5's Avatar
Originally Posted by Thenick619
Ended up being the starter on it, codes are still away but more than likely will come back. Let me just say though when that first start after the starter installed man was it a difference!!! The battery was sitting at 11.9 volts and still cranked over surprisingly. Now time to tackle the hood and trunk issue.
If the battery is at 11.9, it wasn't the starter and you three away good money. A brand new starter may perform for a little while on a dying battery, but in the end you will find out you should have replaced the battery and kept the perfectly good starter you already had. Now you have to pay for both.
Old Mar 11, 2025 | 11:30 AM
  #22
merlinj79's Avatar
On a 2008, the starter was long overdue anyway.
Old Mar 11, 2025 | 11:37 AM
  #23
flybd5's Avatar
Overdue for what? Starters do not have expiration dates or recommended replacement schedules. They are replaced on condition. In dry climates they can last for decades.
Old Mar 14, 2025 | 02:48 PM
  #24
merlinj79's Avatar
I'm in a dry climate and mine don't usually last for decades. Usually the issue is the solenoid, on many units you can replace that separately but depending on labor to access the stater and availability it's often easier just to do the whole thing.
On the motor itself, the brushes wear, although that depends on driving habits, ie how often you start.
When I've taken them apart, there's often carbon dust buildup around the brushes/commutators. In many cases you could probably replace the solenoid, brushes, clean up the dust and be fine. Bearings and windings can also fail, but that's probably rare.
After I retire, I might get back to a place where I have the time and patience (and spare car) to rebuild starters and alternators
rminyard
Jan 22, 2024 02:00 AM
hometown86
Sep 6, 2022 07:11 PM
Jessicajw
Aug 25, 2014 10:30 AM
jhyoo
Oct 30, 2013 12:30 PM
Nenner217
Dec 5, 2012 04:52 PM
