2008 LR2 Alternator Replacement Help
Old Sep 16, 2020 | 04:07 PM
Inkstaind1's Avatar
7th Gear
Default 2008 LR2 Alternator Replacement Help
So our LR2 has left us stranded once again!! Our local mechanics do not work on Land Rovers. They are saying there are special tools needed to swap the alternator, but I did find one video that atleast shows the alternator being put on and the compartment put back together, but it's playing music, no description of tools needed unfortunately. It looked straight forward, just bolts and electrical connections. Has anyone performed this, do you need special tools?
Thanks for the help!
Old Sep 16, 2020 | 06:05 PM
p_gill's Avatar
Mostly basic hand tools
The hard part is removing the intake manifold
This thread shows how to remove the intake manifold
https://www.freel2.com/forum/topic32245.html
With the manifold removed the Alternator is held in with 4 bolts and a couple electrical connections
If you want to replace the overdrive pulley you will need the special tool.
If the replacement Alternator comes with the pulley installed then you don't need the tool
https://www.freel2.com/forum/topic33867.html
Good luck
Paul
Old Sep 16, 2020 | 06:56 PM
Inkstaind1's Avatar
7th Gear
Thanks Paul, I appreciate the input, those are great links you attached.
Old Sep 17, 2020 | 12:21 PM
p_gill's Avatar
Take a look at this thread as well.
The bolt for the drive pulley can come loose.
https://www.aulro.com/afvb/freelande...-i6-owner.html
Let us know what you find out
Thanks
Paul
Connor Kauffman
LR2
Feb 10, 2020 10:53 AM
crackofnoon
LR2
Apr 14, 2019 11:58 PM
Puddin
LR2
Nov 21, 2018 06:12 PM
Itrujillo
LR2
Jun 15, 2018 07:12 AM
ninjaff21
LR2
Jun 4, 2014 11:59 AM
