almost fixed, maybe
Old Mar 25, 2019 | 04:11 PM
crackofnoon's Avatar
Default almost fixed, maybe
Finally finished the replace of alternator in my 2008 LR2. Still not right though. It starts and idles fine, but won't go above 1000rpm. I ran a DTC check with these codes resulting; P0108, P0069, P0335, P2105, P2122, P2127, and P2138. Any guidance on what these codes indicate would be appreciated.
Old Mar 26, 2019 | 01:26 AM
LR2driver's Avatar
Which brand/model is the replacement alternator you installed? Is it reman?
Old Mar 26, 2019 | 01:51 PM
Default crackofnoon
The replacement was a Bosch reman. The model LR2 is an SE.
Old Mar 26, 2019 | 03:34 PM
LR2driver's Avatar
What is the model # of the Bosch reman alternator? Is it a AL0870X ?
Old Mar 26, 2019 | 04:23 PM
Default crackofnoon
Yes it was. I am starting to get curious.
Old Mar 26, 2019 | 04:31 PM
LR2driver's Avatar
I had the same alternator installed (by an independent shop) into my 08 LR2 about six months ago and it's working fine, so at least that confirms this model is compatible with the vehicle.
Some of your OBD2 codes indicate low voltage. When you replaced the alternator, did you ensure that you connected the wire from the alternator (voltage regulator) to the PCM? The PCM commands the voltage regulator on how much voltage to put out based on multiple variables (e.g., load, state of battery charge).
Did you measure the voltage at the battery when the vehicle is running?
Old Apr 14, 2019 | 11:58 PM
Default crackofnoon
Fter replacing the connector for the MAP sensor, my codes have been reduced to one, P2103. I had missed connecting one of the connector plugs for the throttle actuater/body. Connected it but still no throttle control. Any ideas would be appreciated. It takes me a lot of time from the weather and my disabilities. It is a tight car to work on, but I have enjoyed it.
Puddin
LR2
Nov 21, 2018 06:12 PM
Itrujillo
LR2
Jun 15, 2018 07:12 AM
maxamilione
LR2
Aug 9, 2017 01:29 AM
ninjaff21
LR2
Jun 4, 2014 11:59 AM
LaGirl
LR2
Jul 13, 2011 06:10 AM
