2008 LR2 Door Lock
Old May 2, 2023 | 10:29 PM
80knots's Avatar
Default 2008 LR2 Door Lock
The left rear door on my 2008 LR2 will not lock, either by key fob or by manually pushing inside door lock lever.
I’ve tried with door open and closed and seems something not activating inside door.
Might it be the lock actuator?
I would have expected it to at least manually lock.
Any hints or ideas before I start removing door panel?
Thanks
jim
Old May 3, 2023 | 03:08 PM
flybd5's Avatar
The actuator is not separate from the door mechanism. If the actuator is bad the mechanism will not work. If the mechanism is stuck, the actuator will not work. Remove the panel.
Old May 3, 2023 | 04:37 PM
80knots's Avatar
Noted with thanks.
I see they have both keyfob and non keyfob type lock actuators on the aftermarket.
Will they both fit compatibility despite one not active by keyfob?
thx again
Jim
Old May 3, 2023 | 04:54 PM
flybd5's Avatar
Originally Posted by 80knots
Noted with thanks.
thx again
Jim
No idea. I would suggest you stick with the same part number that is on the car now.
Old May 3, 2023 | 05:16 PM
80knots's Avatar
Understood.
Thanks.
Jim
Old May 3, 2023 | 06:39 PM
ThorInc's Avatar
Understood.
Thanks.
Jim
Check this out:
https://www.freel2.com/forum/topic37535.html
lazerbrains
LR2
Nov 17, 2017 11:07 AM
fostera
Nov 9, 2017 11:29 AM
fostera
Nov 9, 2017 11:22 AM
LR2driver
LR2
Jun 25, 2015 07:23 AM
AZRover
Feb 10, 2013 12:00 PM
