2008 LR2 Fuel Tank Pressure Sensor
Old Dec 23, 2018 | 04:30 PM
JMU2013's Avatar
8th Gear
Default 2008 LR2 Fuel Tank Pressure Sensor
Autozone code reader says this is causing my check engine light. Reading as high voltage at fuel rail pressure sensor.
anyone have experience with this or recommend a good service manual?
Old Dec 26, 2018 | 04:30 PM
JMU2013's Avatar
8th Gear
CEL comes on then goes off intermittently - is this normal for fuel rail pressure sensor?
Old Dec 26, 2018 | 11:15 PM
LR2driver's Avatar
What is the OBD2 code number?
Old Dec 27, 2018 | 08:34 AM
JMU2013's Avatar
8th Gear
I believe it was 0193 or something to that effect. “High voltage at fuel rail pressure sensor circuit A”
Old Dec 28, 2018 | 11:04 PM
LR2driver's Avatar
There are a couple things you can try yourself that are not too difficult or expensive:
- You mentioned this problem is intermittent. Check the wiring to the Fuel Rail Pressure Sensor. If it's loose/damaged, then engine vibration might be causing the intermittent problem with bad wiring or a loose connector on the sensor.
- Next thing to try is to replace the Fuel Rail Pressure Sensor. The part is BOSCH 0261230110 and costs less than $60. See this other thread for related info:
https://landroverforums.com/forum/lr...-sensor-89373/
Let us know how it goes.
LR2driver
LR2
May 7, 2018 09:36 PM
tcr6v1
Feb 1, 2017 02:11 PM
TOM R
Jan 5, 2014 09:31 AM
bballjames
Dec 13, 2012 03:01 PM
