2008 LR2 Rough Idle at initial startup
Old Feb 15, 2016 | 02:33 PM
deserttrader's Avatar
4th Gear
Default 2008 LR2 Rough Idle at initial startup
1st post so apologies for any bad form, etc. 2008 LR2 , 120k miles. Rough idle after initial startup. Much smoother (and seemingly maybe better performance ) after warm re-start. Does not correct itself after warmup or after quick shutoff/restart following warmup. . Does not throw any codes. Changed plugs and MAF (along with unrelated PCV fix due to the whistling noise at idle - threw a lean code at that time). Thinking maybe ignition coil, but would think it would either fail or not, and the rough idle and performance does not seem to be bad enough to indicate a miss. Considering buying one new coil and swapping one at a time. Any other ideas? Any chance this is software related? I saw a TSB, but it seemed to indicate that codes would be present if this were the problem. Thoughts are appreciated. Thx in advance.
Old Nov 30, 2021 | 10:02 AM
prkammann's Avatar
Did you ever get this solved? I have an '09 with the same issue
Old Dec 2, 2021 | 12:36 PM
4th Gear
Believe it or not - check your engine mounts. Replacement solved the issue. The vibration was so random that it presented itself as possibly other issues.
Old Dec 2, 2021 | 04:51 PM
prkammann's Avatar
question- are there two fuel pumps? I mean an electrical driven and mechanical? Reason- if the fuel pump was over heating the car wouldn't drive would it? I have the same issue, car won't start when warm. When hot yes, when cold yes, but not when warm, just spins.
Old Dec 2, 2021 | 06:37 PM
flybd5's Avatar
Only one fuel pump. There is nothing in the service manual for "difficult warm start".
Difficult hot start possible causes
  • Injector leak
  • Electronic engine control
  • Purge valve
  • Fuel pump
  • Ignition system
You need to hook a computer to the car and see what error codes it is reporting.
Old Dec 2, 2021 | 07:55 PM
p_gill's Avatar
Are you hot soaking with the key docked?
My LR2 gets really angry if I do this (i.e. stop to get gas press stop but I forget to remove the key from the dock)
https://www.freel2.com/forum/topic29...light=hot+soak
Good luck
Paul
Old Dec 2, 2021 | 07:57 PM
flybd5's Avatar
Good luck
Paul
Heh. Mine does that too, but my gas cap warning is always on and I need to change the purge valve (already checked everything else, including a smoke test).
Old Dec 12, 2021 | 07:44 AM
jay800's Avatar
Same for 2010 LR2, when it first happened many years ago, I just told myself/all that it was a security feature if car-jacked or stolen while FOB was left in. Cleary, that it is not the issue but sounds great!
clovis996
LR2
Jul 21, 2021 11:55 AM
Forhigher
Feb 21, 2020 01:59 AM
BlueSky LR2
LR2
17
Oct 12, 2019 12:14 PM
LR2driver
LR2
Nov 21, 2017 12:17 PM
Kflex
Jan 19, 2016 08:14 PM
