2008 LR2 Rough Idle at initial startup
1st post so apologies for any bad form, etc. 2008 LR2 , 120k miles. Rough idle after initial startup. Much smoother (and seemingly maybe better performance ) after warm re-start. Does not correct itself after warmup or after quick shutoff/restart following warmup. . Does not throw any codes. Changed plugs and MAF (along with unrelated PCV fix due to the whistling noise at idle - threw a lean code at that time). Thinking maybe ignition coil, but would think it would either fail or not, and the rough idle and performance does not seem to be bad enough to indicate a miss. Considering buying one new coil and swapping one at a time. Any other ideas? Any chance this is software related? I saw a TSB, but it seemed to indicate that codes would be present if this were the problem. Thoughts are appreciated. Thx in advance.
question- are there two fuel pumps? I mean an electrical driven and mechanical? Reason- if the fuel pump was over heating the car wouldn't drive would it? I have the same issue, car won't start when warm. When hot yes, when cold yes, but not when warm, just spins.
Only one fuel pump. There is nothing in the service manual for "difficult warm start".
Difficult hot start possible causes
- Injector leak
- Electronic engine control
- Purge valve
- Fuel pump
- Ignition system
Are you hot soaking with the key docked?
My LR2 gets really angry if I do this (i.e. stop to get gas press stop but I forget to remove the key from the dock)
https://www.freel2.com/forum/topic29...light=hot+soak
Good luck
Paul
Good luck
Paul
Good luck
Paul
Good luck
Paul
