201- LR2 Brake rotors/pads
Old Jul 21, 2020 | 05:33 PM
Crosboro's Avatar
Default 2010- LR2 Brake rotors/pads
My local dealer said I need to replace the rear rotors/brake pads, at $600+. Just wondering what anyone else has paid for the same, and if it was done by a non-dealer. Thanks.
Old Jul 21, 2020 | 05:41 PM
Crosboro's Avatar
Update--just got revised info from the dealer--that price included other work that was not indicated. But, I would like to know what others have paid, both dealer and non-dealer.
Old Jul 21, 2020 | 05:42 PM
flybd5's Avatar
$150 or so for both rear rotors at Autozone, another $50 or so for the pads. You should check the parking brake pads while you're at that. You can do the work yourself if you know how (or can read the service manual). If not, take it to any brake shop. Not rocket science.
Old Jul 22, 2020 | 10:49 PM
guy's Avatar
guy
hmmm, yeah. be careful... most times you get what you pay for.
I have noticed the rear disks do wear faster than the front... not all manufacturers are the same.
Time is money, but as @flybd5 suggests, it is an easy job... with the right tools!
Old Jul 23, 2020 | 08:58 AM
flybd5's Avatar
I had mine done with autozone parts, still have to do the parking brake pads, but so far they work perfectly.
Old Jul 23, 2020 | 10:22 AM
merlinj79's Avatar
I've used napa premium rotors (aka raybestos) with textar semi-metallic pads. FLAPS has the pad clips which don't come with the pads, best to replace those too. I've run through two sets of each, with good results. Minimal dust with the semi-metallic pads, I avoid ceramic pads due to occasional towing down long mountain roads, so you could go with ceramic if you're not doing any severe braking duty.
I replace the rotors with the pads, they do wear pretty fast and I don't want to run out of rotor halfway through a set of pads. You might barely get two pad changes out of a rotor set but you'd have to watch it carefully. Front and rear wear differently, have to keep an eye on both of them.
Like flybd5 said, pretty easy as brake jobs go, no special tools or anything. Just pay attention to how the pads and clips come out so you know how they go back in.
The caliper bolts are "patch bolts" with pre-installed loctite, which are supposed to replaced, but you can just clean with a wire brush and apply loctite (I use blue).
Old Jul 23, 2020 | 07:43 PM
LR2driver's Avatar
Originally Posted by merlinj79
I've used napa premium rotors (aka raybestos) with textar semi-metallic pads...
When you replaced your pads, did you notice if the inner pad wore a lot more than the outer pad? I know this is common for single piston brake calipers, but mine are more uneven than I expected. Next time I have the wheel off, I'll have to check if the pins are properly lubed.
Old Jul 24, 2020 | 09:26 AM
merlinj79's Avatar
No, I didn't see that. I do clean and lube the pins and sliding surfaces.
Old Jul 24, 2020 | 11:51 AM
flybd5's Avatar
Old Jul 26, 2020 | 12:41 AM
LR2driver's Avatar
You have to be of a certain age to appreciate that cartoon. It's certainly within my memory
pansygal
LR2
Mar 12, 2016 08:26 AM
Forester
LR2
16
Mar 4, 2015 08:55 AM
metclubin
LR2
Nov 21, 2013 01:47 PM
mich_grand
LR2
Jan 26, 2013 11:39 AM
