2010 LR2 Differential Part# and Labor Cost
Old Nov 29, 2019 | 07:51 PM
jvh2's Avatar
Default 2010 LR2 Differential Part# and Labor Cost
2010 Land Rover LR2 differential is starting to go. Currently making a loud noise. Indie shop says it is the differential. Noticed a Land Rover tech bulletin LTB00342 pointing to the rear differential drive pinion front bearing. Have seen many kits online (including Amazon) with the bearing and related parts to fix this. Yet most shops suggest replacing the whole differential. Why?
Rebuilt entire differential from a Land Rover dealer online lists part no. LR066424 at $1,497.64 + core charge. Is this the newer "better" design differential?
What is the expected labor cost to install?
Also roverlandparts.com lists the differential for the LR2 as part no. LR008502, LR031377 for $1,165.50 + core charge.
What is the differential correct part no.?
Old Nov 29, 2019 | 09:44 PM
p_gill's Avatar
I don’t know the difference between the part numbers you listed
As for the difficulty of replacing just the pinion bearing take a look at this thread
https://www.freel2.com/forum/topic29814.html
good luck
Paul
Old Nov 30, 2019 | 03:18 AM
Jvh75's Avatar
4wd High
Thanks.
Old Nov 30, 2019 | 06:40 PM
jvh2's Avatar
This very thorough description of the noise in the differential points to the bearing and its replacement as the fix. While the repair described is probably beyond most DIYers, what does a dealer or indie shop charge?
Why do some LR2 owners with the noisy differential opt to replace the differential as opposed to replacing the bearing?
When I questioned my local dealer, he said depending on the issue, they would replace the bearing or the differential with a new or rebuilt.
Old Dec 10, 2019 | 08:15 AM
jvh2's Avatar
Default Part Numbers for LR2 Differential
Dealer confirmed for my LR2 VIN:
LR066424 is for a rebuilt differential.
LR031377 is for a new differential. (Supercedes part no. LR008502)
Price difference from the dealer is only $100 more for the new differential ~$1600 vs $1500.
StarView2000
LR2
Oct 28, 2019 01:46 PM
BG Simons
Mar 9, 2015 12:19 PM
Nitrolr2
LR2
Nov 5, 2010 07:33 PM
lin8810
LR2
Jul 24, 2008 05:51 PM
scarrittjd
LR2
Dec 5, 2007 05:42 PM
