2011 Brake Light Bulb - Not sold locally?
I believe 7528 is the reverse (back-up) lamp.
I recently replaced the left/right stop (brake) lamps on my 08 LR2 and used Philips P21/5W 12499. I bought a pack of two on eBay, but they probably carry them in local stores, too. Suggest you replace both sides at the same time.
One of the largest light bulb reference sites on the internet has incorrect bulb information for the LR2. If you don't have your owner's manual to reference, then it's good practice to verify part #'s across different, independent sources.
japowell8200 (02-23-2021)
Yep, that's a #921 bulb. Since you mentioned it, and brake lights are important, I should probably replace that one now as well. Another to-do.
[QUOTE=LR2driver;762740]I believe 7528 is the reverse (back-up) lamp.
One of the largest light bulb reference sites on the internet has incorrect bulb information for the LR2. If you don't have your owner's manual to reference, then it's good practice to verify part #'s across different, independent sources.[/QUOTE
Wow, you guys are awesome! Thank you for this info.
