2011 Brake Light Bulb - Not sold locally?
Old Feb 23, 2021 | 01:58 AM
japowell8200's Avatar
6th Gear
Default 2011 Brake Light Bulb - Not sold locally?
I can’t seem to locate the correct brake light bulb when looking at local auto parts stores. 7528 bulb is what their website says but it doesn’t fit.
Anyone else ever have the same issue?
Old Feb 23, 2021 | 10:26 AM
flybd5's Avatar
Which bulb are you talking about, the one at the top of the hatch or one of the left/right bulbs? AFAIK all the bulbs are available at your local Autozone or other auto parts store.
Old Feb 23, 2021 | 01:44 PM
LR2driver's Avatar
I believe 7528 is the reverse (back-up) lamp.
I recently replaced the left/right stop (brake) lamps on my 08 LR2 and used Philips P21/5W 12499. I bought a pack of two on eBay, but they probably carry them in local stores, too. Suggest you replace both sides at the same time.
One of the largest light bulb reference sites on the internet has incorrect bulb information for the LR2. If you don't have your owner's manual to reference, then it's good practice to verify part #'s across different, independent sources.
Old Feb 23, 2021 | 01:53 PM
flybd5's Avatar
Those are the ones in the cluster of lights in the rear, but above the tailgate there is another stop lamp, that's a W16W.
Old Feb 23, 2021 | 01:59 PM
LR2driver's Avatar
Yep, that's a #921 bulb. Since you mentioned it, and brake lights are important, I should probably replace that one now as well. Another to-do.
Old Feb 23, 2021 | 02:11 PM
6th Gear
[QUOTE=LR2driver;762740]I believe 7528 is the reverse (back-up) lamp.
One of the largest light bulb reference sites on the internet has incorrect bulb information for the LR2. If you don't have your owner's manual to reference, then it's good practice to verify part #'s across different, independent sources.[/QUOTE
Wow, you guys are awesome! Thank you for this info.
Old Feb 23, 2021 | 02:12 PM
6th Gear
Bingo! And thank you for your response!
Old Sep 17, 2021 | 01:16 PM
chieftel's Avatar
Hi. i have the same problem purchasing brake bulbs from my local store. i need the bulb to have offset pins. and anybody confirm the 12499 has offset pins ? thank you all for your time. colin
Old Sep 17, 2021 | 01:17 PM
chieftel's Avatar
japowell8200
Feb 23, 2021 12:36 AM
kpl1228
Feb 19, 2012 07:33 AM
blcp86
Aug 27, 2009 04:36 PM
nickd503
May 16, 2009 02:05 PM
nynole
May 1, 2009 10:43 PM
