2011 LR2 HDC Fault Unavailable, Will Not Shift
Old Aug 9, 2022 | 01:11 AM
flybd5's Avatar
Originally Posted by LR2driver
Do all bi-directional scanners require an independent power supply? I've never heard of that before now. Is this requirement unique to JLR SDD?
Or is the power supply only needed while programming LR2's systems, not for all the other functions?
It's only required when messing with the ECU, to try to avoid bricking it due to power failure. SDD complains if it doesn't detect it.
Old Aug 9, 2022 | 01:59 PM
LR2driver's Avatar
That makes sense. thx
Old Aug 21, 2022 | 02:59 PM
LR2driver's Avatar
I'm thinking of getting a Mongoose cable (actually, a knockoff Mangoose cable). However, I'm not planning to reprogram anything so I'm not going to buy a power supply.
Is the SDD software structured well enough that I can use it for read-only measurements without accidentally navigating to reprogramming?
Old Aug 21, 2022 | 03:34 PM
ThorInc's Avatar
Yeah you can fool around with it to a degree, just put a regular battery charger on it. The software is going to complain or not give you options if your voltage is too low. BTW, if you have two vehicles just leave the other one one running with a jumper cable. But, if you are going to flash modules, get a 25amp battery SUPPLY.
Old Aug 21, 2022 | 03:38 PM
flybd5's Avatar
The user interface sucks, so be vewy, vewy careful.
flyer08
LR2
19
Dec 29, 2020 09:24 PM
cipher982
Nov 9, 2019 11:22 AM
tchaudhry10
Apr 18, 2019 04:28 PM
mrb06lr3hse
Aug 18, 2012 10:26 AM
martin08
Dec 10, 2011 08:10 PM
