2011 LR2 133k miles
Have a single fan design not turning on. How do you remove the cover over F3, the fan 80a fuse? Want to try fuse before fan replacement. I think this plastic covers F3, F4, and F5.... Strap fuse?
See pic. Red circle around fuse 3, 4, and 5. Terminal held with nut runs under plastic cover.
I removed nut, still could not remove section. Explain if possible how to remove
The red arrow points to the locking tab (the relay has been removed, but this is a capture from a youtube video). You will need to gently push the tab out (to the right in this image) to unlock the cover.
Note: I am not certain which fuse is for the electric fan and you may have to remove more covers.
If you figure out which fuse is the right one then take some pictures and post it here for other to see.
Note: did you check for voltage at the fan module? If you have battery voltage and the fan is not coming on then the controller may be broken or the fan motor may have failed or both.
The fan will spin if you apply 12 volts and a good ground directly to it inputs. (just disconnect it from the controller)
To uncover the fuses F17 - F21.
To get to them you have to release the two locks and then lift the panel.
Here are the two locks that need to be released
Remember to disconnect the battery first then push the lock toward the center of the fuse box using a small flat blade screwdriver
And here is a picture of the fuses behind the cover
Thanks. Got the adjacent cover and cover needed off F3... a strap fuse that has perfect continuity. So fuse good.
Taking off the manifold to replace the fan motor and regulator is more than I have time for, so indy shop it goes unless some has another idea.
Thanks to each for your input.
Loading another post.... What is it? Maybe from LR3?
If you are going in (or are having someone do it for you) then get the parts that should be replaced if the manifold is removed
LR006071 - Thermostat
LR001491 - Screw for Thermostat (Qty 4)
LR001442 - Coolant Hose for heat exchanger
LR000491 - Bolt for Heat exchanger hose
LR001505 - O-Ring for heat exchanger hose
LR019341 - engine to expansion tank coolant hose (this will likely leak after removal)
LR001454 - intake manifold gasket Qty 6 needed I bought aftermarket parts from Victor Reinz and the quality appears excellent and the cost was very low
And share the link about how to remove the manifold with who ever is doing the work
Especially this quote from a random person in the UK that owned a LR2 3.2
Bloody hell, i think I’ll just wait for it all to blow up.....
Good luck
Paul
PS I installed a Volvo Twin Fan setup in my LR2 3.2 after the single fan failed and to save on cost I installed a Radiator Fan (Siemens / VDO) twin fan in my Volvo S80 3.2. Note: my Volvo Fan didn't fail it just made too much noise for me to tolerate and I still have the old worn out fan if the new fan fails. I did have to shim the VDO fan very slightly to prevent the Fan blade from rubbing on the shroud (the interference was very minor and it would have eventually stopped making a rubbing noise) but I have no tolerance for that so I fixed it prior to installing it.
