2011 LR2 Radiator Fan Fuse
Old Jul 19, 2022 | 11:50 AM
flyer08's Avatar
Originally Posted by p_gill
If you are going in (or are having someone do it for you) then get the parts that should be replaced if the manifold is removed
LR006071 - Thermostat
LR001491 - Screw for Thermostat (Qty 4)
LR001442 - Coolant Hose for heat exchanger
LR000491 - Bolt for Heat exchanger hose
LR001505 - O-Ring for heat exchanger hose
​​​​​​LR019341 - engine to expansion tank coolant hose (this will likely leak after removal)
LR001454 - intake manifold gasket Qty 6 needed I bought aftermarket parts from Victor Reinz and the quality appears excellent and the cost was very low
And share the link about how to remove the manifold with who ever is doing the work
https://www.freel2.com/forum/topic32245.html
Especially this quote from a random person in the UK that owned a LR2 3.2
Good luck
Paul
PS I installed a Volvo Twin Fan setup in my LR2 3.2 after the single fan failed and to save on cost I installed a Radiator Fan (Siemens / VDO) twin fan in my Volvo S80 3.2. Note: my Volvo Fan didn't fail it just made too much noise for me to tolerate and I still have the old worn out fan if the new fan fails. I did have to shim the VDO fan very slightly to prevent the Fan blade from rubbing on the shroud (the interference was very minor and it would have eventually stopped making a rubbing noise) but I have no tolerance for that so I fixed it prior to installing it.
Holy heck... Am I spending more than car value?
Old Jul 21, 2022 | 04:21 PM
flybd5's Avatar
You play, you pay.
Old Jul 21, 2022 | 07:16 PM
LR2driver's Avatar
Originally Posted by flybd5
You play, you pay.
I can testify to that (replaced engine last winter).
You have to balance the cost of repairs/maintenance against the replacement cost of another comparable vehicle. In today's market, it often makes more financial sense to invest in what you already have than buy a replacement. You never know what faults lie hidden in a replacement. As they say, "Better the devil you know than the devil you don't know."
Old Jul 21, 2022 | 07:45 PM
flybd5's Avatar
Even easier.... If every time you have a tiff with your wife you replace her, your life will be spectacularly miserable.
Old Jul 22, 2022 | 11:54 AM
p_gill's Avatar
The LR2 is a complex machine and it needs preventative maintenance.
I compiled information from LAND ROVER and VOLVO as well as information about failures from the internet.
I separated that information into three groups
- High Mileage Maintenance items for 3.2
- Typical repairs for high mileage 3.2
- Less common repairs
Its been almost 4 years since I started that thread https://www.freel2.com/forum/topic32504.html
Based on the fact that I wanted to keep my LR2 for a very long time and that my Son needed a car I searched for a Volvo 3.2 for him (with the goal of keeping cost down https://www.matthewsvolvosite.com/fo...7687&start=190)
Here is the list of items that I had to repair on the S80 (I highlighted in Bold all of the items that I also replaced om my LR2 over the last 14 years)
$62.53 --- (31401556) --- Booster O-rings
$40.35 --- (DENSO 5344) --- Sparkplugs
$58.28 --- (LR006071) --- Thermostat
$00.66 --- (LR001505) O-ring for 30713530
$24.29 --- (30713530) --- Coolant hose
$68.85 --- (31272677) --- Oil Filter housing
$18.92 --- (LR006076) --- Idler pulley
$18.92 --- (LR006076) --- Tensioner Pulley
$08.97 --- (PK060473 CONTITECH) --- Aux Belt
$112.70 --- (LR021634) --- Motor Mount
$23.24 --- (30680474) --- Torq Mount
$15.76 --- (UD1306) --- Front Brake Pads (Amazon close out price, typical price is ~$75)
$523.23 --- AC repair
$43.37 --- Overdrive pulley ProParts Sweden 28436803
$323 ---- Radiator (Prem Air type)
$281 --- Radiator Fan (Siemens / VDO)
$34.4 --- (31272732-MFG14) BOSCH Fuel Pressure Sending unit
$11.61 --- (31300263) B+ Battery Clamp
$00.00 --- Loaner Battery from the Land Rover (Note: it is slightly too large and the cover only latches on one side)
$156.00 --- Mirror repair
$120.00 --- H8 GTR Ultra LED 2.0 bulbs
$06.00 --- Brake light bulb
$02.05 --- (30658215) Receptacle Housing for the MAF Sensor
$09.43 --- (31214625) Volvo Emblem
$81.95 --- 5350195100 INA Overdrive Pulley
$64.78 --- 38495 Gates Tensioner
If you add up all of the Bold Items the cost isn't very high.
However if you don't get out in front of it the cost can be very high.
I wrote this on another thread
The way that I think about it is this.
- The Thermostat is a known failure point at ~10 years
- Failed Thermostats can lead to coil pack failures
- Failed coil packs can lead to misfires and Catalytic converter failures
- And in severe instances a failed Thermostat (or possibly failed radiator fan) can lead to head gasket failure
For me it is easier to just replace the Thermostat and the Radiator Fan.
I expect that going through my list twice will get you to 300K miles with a very low probability of major mechanical failure
If you want more than 300K then you will need to look into replacing the Timing chain and a long list of additional items that will wear out
At this point I completed my first pass through the list and I am above 100K for both vehicles
Thanks
Paul
Old Jun 25, 2023 | 01:27 PM
George Grund's Avatar
5th Gear
Default Please attach link of you tube video
where is the you tube video? to this
The red arrow points to the locking tab (the relay has been removed, but this is a capture from a youtube video). You will need to gently push the tab out (to the right in this image) to unlock the cover.
Old Jun 25, 2023 | 01:33 PM
flybd5's Avatar
I'm sorry, I don't remember. Perhaps Google Image Search can find it for you.
Shalin Sathiah
Apr 24, 2020 03:10 AM
Daniel Ortman
Mar 15, 2018 07:35 PM
samfb24
LR2
Jun 6, 2016 12:06 PM
Disco_Fever
Dec 7, 2013 04:05 PM
jmt
Dec 23, 2007 06:16 PM
