2013 injectors
Old Oct 27, 2022 | 11:31 AM
merlinj79's Avatar
Originally Posted by flyingscot
quick question - what initiates fuel injector changeout - mileage / rough running? Are there any additives to run through the system to pro-long life / achieve better performance - I've always stayed clear of 'em - put them in the same category as snake oil but if anyone has any positive experience I am interested for sure.... type of treatment / frequency & volume of addition / etc.
I've been using techron for decades, either via chevron gas or a bottle from flaps. Have never had an issue with injectors on six cars or two motorcycles. Although any tier one gasoline is probably good enough.
Liqui-moly also seems to be good stuff, I've started using Ceratec on my higher-performance vehicles (including the LR2). There is plenty of discussion on the interwebs about liquimoly, but the folks who have the most to lose (Porsche, etc owners) have concluded it's legit.
In general I would assume that 99% of additives available are snake oil, unless proven otherwise. It took a lot of reading to sell me on liquimoly.
Old Oct 27, 2022 | 11:46 AM
flyingscot's Avatar
thx Merlin - all ur research will serve me well - I'll likely try it in my Euroboxes - high compression units - in an attempt to prevent/reduce internal scale - hopefully keep the cars running smooth longer and even avoid injector replacement.
Old Oct 27, 2022 | 12:16 PM
flyingscot's Avatar
thx for ur note - how many miles b4 injector changeout?
Old Oct 27, 2022 | 12:22 PM
flybd5's Avatar
Before changing injectors, get yourself an inexpensive ultrasonic jewelry cleaner (preferably one with a heater) and some decent solvent. Remove the injectors and leave them overnight in the cleaner with enough solvent to cover them. More often than not this will dislodge whatever ails them and save you the cost of new injectors... and you can use it to clean other things too.
Old Oct 27, 2022 | 01:35 PM
ourx15's Avatar
I changed them at 167000 km. Along with a new Haldex pump, rear main seal and timing cover gasket. I think I have an exhaust manifold to change in the near future, but I hope that will be it for a while. Who knows…….
ourx15
LR2
Jul 26, 2022 11:08 AM
LR2driver
LR2
Jul 15, 2022 09:24 AM
RhinoRover
Nov 2, 2017 10:10 PM
SocalD1
May 3, 2016 08:34 PM
SinisterMoose
Feb 10, 2016 10:33 AM
