2013 LR2 won't turn on
Old Dec 1, 2023 | 01:06 PM
Wellshoot!'s Avatar
3rd Gear
Originally Posted by flybd5
Hook up a reader to the truck which understands LR modules and post a reply here with the codes it returns.
Got to get my hands on one first.. Hard to drive the dang thing to a shop when it wont run haha.
Old Dec 1, 2023 | 05:13 PM
flybd5's Avatar
Order an Autel from Amazon. They deliver.
Old Dec 9, 2023 | 12:49 PM
Wellshoot!'s Avatar
3rd Gear
So after a little bit of waiting, we now have two codes that showed up.
P068A= Engine control module/Powertrain control module- power relay de-energized too early
P0114= O2 sensor circuit bank 2 downstream sensor: last occurrence - maximum strength
Sooooo, i erased codes and attempted to start the vehicle again. Same continuous clicking from what seems to be the starter relay. no attempt at all to turn the vehicle over.
i turned the ignition off for 5 minutes, hooked the reader back up and get no codes. All the while the check engine light is still on. i have already went over relays in the engine bay and inside the cab. Any other thoughts FLYBD5?
Old Dec 9, 2023 | 01:34 PM
flybd5's Avatar
Have the battery tested and charged at your local auto parts shop, if it doesn't check out good, replace it.
Old Dec 9, 2023 | 02:26 PM
ThorInc's Avatar
As suggested above, get the battery LOAD tested. Voltage is one thing, the ability to deliver amperage, LOAD, is another. In addition, remove the skid plate and have someone sit in the car while you hit on the starter with a rubber mallet. If it starts, get your starter rebuilt.
Old Dec 9, 2023 | 02:51 PM
flybd5's Avatar
IMO LR2 starters are inexpensive enough to be replaced rather than be rebuilt, but that's a matter of opinion, I guess.
Ham803
LR2
22
May 28, 2022 05:09 PM
Mark P
LR2
Oct 30, 2021 12:28 PM
Carlos Moreno
LR2
Mar 13, 2016 02:17 PM
LR2driver
LR2
Jan 12, 2015 06:07 PM
rscisme
LR2
Jun 27, 2014 08:37 PM
