208k miles
Old Feb 14, 2021 | 05:28 PM
Grace Collins's Avatar
Default 208k miles
Hey everyone. I have a 2009 LR2 with just over 208,000 miles on it. Original engine and trans. I’ve been looking to buy a new vehicle because I figure at 200k+ this truck is probably at the end of its life. That said, I can’t find anything I like when comparing it to my LR2. So my question is this: how many miles can I expect to get out of this thing before the engine blows? Please know that I do keep up with maintenance and fixing issues as they arise. But I’m wondering if I could get another 5 or so years out of this thing. I just love it so much.
Thanks.
Old Feb 14, 2021 | 07:08 PM
flybd5's Avatar
Thanks.
As long as you take care of it, perform the services as required and stay on top of any issues that you may run into, the truck should last a lot longer. If you are concerned about the engine, perhaps you should try an additive such as Liqui-Moly's MoS2 engine oil treatment. I use it at every oil change and the engine runs noticeably quieter and smoother. MPG has slightly improved as well. I had the oil changed today and used their engine flush 10 minutes before the change as stated in the directions. They make VERY good products.
Keep in mind as well that it is not hard to find parts for this truck using a service like car-parts.com that searches the shops that buy the ones that have been in accidents, for example, and sell the good parts out of them.
Of course, if it breaks down really bad, you could always find another one with a lot less mileage and keep on trucking.
Old Feb 14, 2021 | 08:16 PM
ThorInc's Avatar
I'll drive mine till it's no longer viable to fix (regular and proactive maintenance being done of course). My last vehicle was 21 years old...............mint condition until an unfortunate mishap.
One thing to note, the LR2 has a ton of electronic modules. They can cause a headache and a butt ache to track down and fix so be prepared to learn about the inner workings or it could get expensive.
Old Feb 16, 2021 | 12:15 AM
LR2driver's Avatar
I wonder what the weak point in the LR2 is, the engine or transmission? For the 2008-09 model years, it's a Volvo engine and an Aisin tranny. Fortunately, it's not a turbo so it won't suffer the long-term stress effects from pushing the engine to its limits.
Old Feb 16, 2021 | 09:07 AM
flybd5's Avatar
Apparently, neither. It appears to be the rear differential. The engine and transmission appear to be durable and reliable as long as you don't terribly abuse them. In particular the factory installation of a transmission oil cooler likely helps to protect it. In the turbocharged models, it's not the engine that fails, it's usually the turbocharger itself.
Old Feb 17, 2021 | 03:03 AM
ThorInc's Avatar
Yep, the rear diff is definitely a weak spot; cheap factory bearings and, of course, the pinion bearing is/was too small or simply, due to design, does not get sufficient lube. I did replace mine with one refurbed from the UK.
Old Feb 17, 2021 | 05:02 AM
Ormanuel's Avatar
If your VR2 is outdated and you take good care of it, it will last 10 years more, the main thing is that the cost of repairs does not exceed its cost on the used market)
Old Feb 17, 2021 | 07:32 AM
flybd5's Avatar
That's why it is a good idea to start learning how to do things yourself, and how to find parts from "retired" LR2's.
kind16
LR2
Sep 15, 2019 01:00 PM
Newlr2guy
LR2
Jun 29, 2019 08:29 AM
Kristofer Johnson
LR2
Sep 26, 2018 08:00 PM
ffcol
LR2
Nov 25, 2013 09:09 AM
lin8810
LR2
Jul 24, 2008 05:51 PM
