3.2 Thermostat housing failure modes
Old Jun 16, 2021 | 06:32 PM
p_gill's Avatar
Default 3.2 Thermostat housing failure modes
LR2 3.2 Owners,
I just watched a video of a XC90 3.2 with a failed Thermostat.
The surprising thing is that the failure mode appears to be non standard.
Common failure mode for 3.2 Thermostat
1. Cracked plastic due to return spring shear force and thermal cycles (Fatigue or Creep rupture is the likely phenomenon)
2. Plastic failure of the O-ring groove at its thinnest section
Mode #1
Failure mode #2
Arrow point at location of the failure, I'll search the internet for the picture of the failed part
New Failure mode
Conclusion
I would need to get a closer look at the actual part to confirm but it appears that the plastic housing has deformed due to heat. Two possible reasons.
1. the coolant leaked out and engine got very hot and this warped the plastic
2. an aftermarket Thermostat was used and it was built with an inferior plastic
Beware of aftermarket parts for components like this.
Here is the video
Thanks
Paul
Recommendation
Get the Thermostat in a Volvo box or Land Rover box.
Don't buy aftermarket.
And change it every 10 years
thom_77
Apr 21, 2021 10:47 AM
LR03NJ
Feb 19, 2017 07:16 AM
Tratcliffe
May 4, 2016 07:12 AM
erictj
Sep 2, 2014 03:25 PM
ZB-30
Nov 6, 2012 11:07 AM
