AC not working on 2008 LR2
Old Oct 23, 2024 | 06:45 PM
aperry's Avatar
Default AC not working on 2008 LR2
So, I own a 2008 Lr2 with 134,000 miles and the AC has not worked since I bought the vehicle in December of 2023. The system holds vacuum and pressure but will not blow cold. The fan speed/direction is all accurate, it just won't blow cold. So far, I have replaced the high-pressure switch, compressor, condenser, expansion valve, climate control module, fan control module and the evaporator temperature sensor.
Has anyone seen anything like this or have any ideas?
Old Oct 25, 2024 | 05:20 AM
guy's Avatar
guy
Playing the game of musical parts is the most expensive way to solve the problem.
Get your hands on the workshop manual and read about the aircon system operation in the vehicle.
“does not blow cold”. a few ways to interpret this: does the fan work? is the blend door actuator or apparatus working? is there any air flow? is the evaporator cold to touch? is the control module allowing the operation?
“has not worked since purchase”… well, the good news is, we’re coming up to winter.
Bad news, you have less to go on in your root cause analysis.
Viking1
LR2
Jun 8, 2024 09:32 PM
OvalPiston
LR2
Sep 17, 2023 05:38 PM
Dayton
Jul 10, 2018 07:56 PM
lotek10101
LR2
Jan 26, 2016 02:26 PM
Kflex
Jan 19, 2016 08:14 PM
