ACETONE IN FUEL; TO INCREASE GAS MILEAGE AND USING PREMIUM FUEL
Old May 23, 2008 | 01:09 PM
dlonesty's Avatar
Default ACETONE IN FUEL; TO INCREASE GAS MILEAGE AND USING PREMIUM FUEL
dOES ANYONE USE REGULAR INSTEAD OF PREMIUM? IRF NOT, WHY?
hAS ANYONE TRIED ACETONE IN FUEL TO INCREASE GAS MILEAGE? aRE THERE RUBBER PARTS IN THE FUEL SYSTEM TO BECOME DAMAGED BY ACETONE...MIXTURE IS 1-3OZ. PER 10 GAL. OF FUEL
Old May 23, 2008 | 11:27 PM
jenin5280's Avatar
Default RE: ACETONE IN FUEL; TO INCREASE GAS MILEAGE AND USING PREMIUM FUEL
I use mid grade. In Colorado, that's 87 octane. I've never put in 85. It'll make your engine knock. I used premium once (91). Lost a few MPGs.
Old May 28, 2008 | 09:10 AM
Stay away from Acetone if you don't want to build up some long term expensive problems.
Use on high octane, 87 is not mid grade in most states it is considered to be regular.
For what you save at the pump, you will loose in MPG and decarbong and or replacing your valves.
tnixon44
Apr 24, 2014 08:36 AM
johnkbl
Nov 23, 2010 11:50 PM
dlonesty
May 23, 2008 01:01 PM
pblake4
Feb 7, 2008 07:21 AM
bdud98disco
Jul 11, 2007 08:02 PM
