Bonnet Open? Off with its head!
Are you like me, tired of the repeated failure of the bonnet/hood microswitch failing because some poor underpaid sod of a British engineer installed it in exactly the best way for it to catch as much dirt as possible? Pissed off that it keeps telling you "Bonnet Open" and won't let you arm the alarm? OFF WITH ITS HEAD!
The microswitch is behind the driver side latch of the hood. Find the wires (just two to an orange connector), cut the wires as close as possible to the connector, then strip and splice them together. The switch closes the circuit when the hood is down, so splicing the wires tells the little Brit inside the car to STFU and not bother you again. The alarm also works fine now. Boom.
I don't need the Brit midget in the car telling me the bonnet is open.
Just fix it with the redesigned part
or put a paperclip in the glove box
LR065340
Replaces
LR002794, LR024358, LR041431, LR054331, YUE500090, YUE500150
Cost about $40
Quote "Change the right hand bonnet lock, but make sure it is the newer modified type which was brought in to solve this problem once and for all."
https://www.landrovermerriamparts.co...MtMmwtbDYtZ2Fz
https://www.freel2.com/forum/topic35334.html
LR065340
Replaces
Cost about $40
How does one install the redesigned part? It appears to be designed for a slightly shorter cable. When I attempted to install mine the cable was about 1cm too long, so would not pull on the latch. I had to re-install the old part for now.
The part I have is "LR065340 Range Rover Sport LR2 LR3 LR4 Latch Anti Theft Hood Alarm Switch"
I replaced the switch a few years ago, been fine ever since. Problem must have been the switch, not the bonnet lock.
LR065340
Replaces
Cost about $40
LR065340
Replaces
Cost about $40
