Bypass cooling fan module
Old Jun 4, 2016 | 04:34 PM
samfb24's Avatar
Default Bypass cooling fan module
Hey guys, I'm troubleshooting an overheating issue on my lr2. I've identified that the cooling fan is not spinning up at all. I want to bypass the control module/relay on the cooling fan and go directly to the battery to test whether the fan is bad, or the module is bad. I'm hoping one of you guys can give me some guidance on how to do this.
Old Jun 6, 2016 | 12:06 PM
p_gill's Avatar
Default Did you check the fuse?
Sam,
The fuse should be under the plastic cover in the attached picture
Good Luck
Paul
PS the fan is PWM controlled and it can be bypassed, but you should proceed with caution.
Old Apr 29, 2019 | 01:39 AM
Dobenja66's Avatar
Default Hot to check the fuse
I've never seen a fuse like this. How do I check to see if the fuse is good or not?
What kind of fuse is this?
oliver1071
LR2
May 6, 2021 02:39 PM
Mecevans
Aug 9, 2015 02:30 PM
btp226
Engine & Internal
Oct 21, 2007 08:37 PM
igriego
Mar 14, 2007 01:53 PM
vonfonk
May 6, 2006 06:50 PM
