Coolant system issues chipped aluminum nipple at front of motor from lower coolNt li
Old Nov 5, 2019 | 08:01 PM
Ratpack08's Avatar
Default Coolant system issues chipped aluminum nipple at front of motor from lower coolNt li
Are there any work arounds for a chipped aluminum nipple on front of the motor where the lower radiator hose connects to the side of the VOLVO motor on an 08 LR2 i was considering stubbing out the fancy connector and using a standard hose clamp. Any guidance or any other train of thoughtthat may be a solution to my coolant system issue
Thank you
Old Nov 6, 2019 | 01:22 PM
p_gill's Avatar
Can you be more specific?
Take a look at this link
https://www.advancedfactors.co.uk/32...es-11996-c.asp
Is the broken part LR002686 ???
If yes then the pipe is replaceable but getting to it is non trivial.
Good luck
Paul
Martimouse55
LR2
Jan 29, 2019 12:13 PM
Gil Yontz
Range Rover L322 (3rd Gen)
Oct 5, 2018 03:20 PM
99DiscoFlyer
Nov 19, 2015 12:52 AM
Phatrowles
Feb 8, 2013 09:28 AM
Savannah Buzz
Nov 29, 2011 09:40 PM
