Crank, Fire, Die (unless MAF unplugged)
Old Aug 26, 2021 | 09:38 PM
behrend's Avatar
Default Crank, Fire, Die (unless MAF unplugged)
Hi all, new to the forum. Have a 2013, LR2 with the 2.0T. Have an issue with it starting and immediately dying unless the MAF is unplugged. I replaced the MAF with a Delphi AF10432. Same problem persists. With the MAF unplugged, it idles decently and drives (not great but will drive). I checked for intake leaks by spraying ether and WD-40 around the intake areas with the engine running and didn't notice any change in RPM or stability. I had a scanner hooked up and didn't see any PIDs out of range that were obvious.
Any idea where to go from here? I am pulling my hair out on this one.
Old Aug 26, 2021 | 10:39 PM
flybd5's Avatar
There are several threads in the forum with similar symptoms and several different LR models. But you said you have no error codes off the OBDII port? Maybe you need to take the car to someplace like an Autozone and have it read with a more advanced or up to date reader.
Old Aug 27, 2021 | 08:33 AM
merlinj79's Avatar
You might also search the forum below, it's mostly Brits and most of them have a diesel (this site seems mostly people with gas/petrol 3.2 motors).
https://www.freel2.com/forum/index.php
boxsterrs60
May 19, 2019 12:39 PM
binvanna
Dec 18, 2017 09:33 PM
jasons
Aug 11, 2009 10:09 PM
ezikial4
Jun 28, 2009 08:26 PM
jkid
May 16, 2008 08:55 PM
