Did I fry my new fan motor?
Old Yesterday | 05:40 PM
Johnny2x4's Avatar
Default Did I fry my new fan motor?
My LR2 was running warm and I noticed the radiator cooling fan was not turning on. I read some threads about this and after checking fuses the next step in troubleshooting was to disconnect the wires from the fan control module to the fan itself and connect wires directly between the fan and the battery to see if it would run.
I did that and the fan didn't move so I decided to purchase a new fan assembly.
Before installing the new fan assembly I wanted to make sure it would run so I performed the same test. It ran for a second and stopped, even with the wires still connected.
So did I fry this new fan motor? It reads 0.3 ohms between the positive and negative.
Is that not the correct way to test the fan motor?
Old Today | 12:42 AM
LR2driver's Avatar
It sounds like you're doing it correctly. The fan should run with power applied to the fan connector.
Are you sourcing your power directly from the battery? I ask because I tested mine with a Power Probe style deviice and it ran momentarily and then stopped because the 10A circuit breaker in my device popped (easy to reset with the push of a button). The fan can draw 40+ amps so if you have any type of current limiter inline with the power source it may open the circuit.
I don't know the resistance of the fan so can't help with that.
Is this a brand-name replacement part or an eBay special?
Old Today | 07:55 AM
Johnny2x4's Avatar
It was a cheapo fan since the OEM price was over $1,000.
I didn’t use a fuse or breaker, just straight wires. No one mentioned anything like that in the threads. I believe the fan fuse in the fuse block is an 80 amp.
Old Today | 10:59 AM
LR2driver's Avatar
That 80A fuse can support one fan (standard on USA models) as well as two fans (more common elsewhere) for the dual fan model.
Maybe there is a problem in the fan connector and cable. As a last try, connect power as close to the fan power terminals as possible, bypassing the connector and cable.
Since the fan started for a moment and then stopped, sounds like a bad fan. I would not make the significant effort to replace the fan assembly if your new fan is not working with a direct power test. Contact the seller about a replacement and ask if other customers had the same issue.
graym
Oct 1, 2024 05:56 AM
landroverdude
Dec 4, 2019 06:31 AM
zuke
Jul 4, 2017 06:28 PM
jmt
Jan 14, 2008 05:01 PM
