Driver Side Window not working. 2013 LR2
Old May 10, 2022 | 10:10 AM
ken25302's Avatar
Post Driver Side Window not working. 2013 LR2
Left window down, the rain got on the switch, replaced the switch. Now window switches not working. Power to switch not 12 volts about 8. Mirrors not working, Passenger side windows working front and back with their own switch, driver side rear door window not working. Did reset please help?
How to reset windows and sunroof
Old May 10, 2022 | 04:17 PM
flybd5's Avatar
Dry the old switch assembly with a hair dryer, reinstall it and try that. Otherwise you may have to have the door module reprogrammed.
Old May 11, 2022 | 06:42 AM
guy's Avatar
guy
8 volts?
Did you replace with used or new switches?
Nonetheless, I’d try 1 simple step first: Perform a hard reset. Disconnect the battery. Touch the leads together. Reconnect the battery.
Then go through your window reset routine (which is also described in the owners manual). BTW This really only works if your battery is fully charged to 12.6 volts prior to reconnecting.
Old May 18, 2022 | 07:01 PM
guy's Avatar
guy
only 1 post and no follow up??
Matt Thaller
Sep 21, 2015 08:36 AM
jimvw57
Jun 7, 2015 09:04 PM
jimvw57
May 25, 2014 06:40 PM
LeakyDisco
Jun 21, 2013 08:22 PM
JBRIII
Dec 29, 2006 06:02 PM
