Engine fan module?
Old Jun 21, 2023 | 08:29 PM
paige-lr2's Avatar
7th Gear
Default Engine fan module?
2015 LR2 - Been having issues with the fans for a while. The radiator fan runs very loud and very often (think it’s when the a/c is on). No system messages showing and don’t have a diagnostic tool. Temp gauge has never risen above normal, so no overheating issues.
Just tested the cooling module and switched the connectors, only one fan will come on at a time. Is the module bad? Should I replace it? Or are there some other things I can test before spending the money ordering a module?
Old Jun 22, 2023 | 04:14 AM
ThorInc's Avatar
Read through this:
https://landroverforums.com/forum/lr...-115036/page2/
Old Jun 22, 2023 | 07:45 PM
flybd5's Avatar
What modules are you talking about and what model LR2 do you have? The US gas LR2 comes standard with a single fan assembly and one fan module. The diesel model comes with dual fans and again one fan module, with a second cable connecting to the second fan. What you are describing does not sound like an LR2. If you have dual fans you will have to replace it with a dual fan assembly. Those can be bought fairly inexpensively in the UK. Check ebay.
Old Jun 22, 2023 | 10:08 PM
paige-lr2's Avatar
7th Gear
yep, definitely have a two fan assembly and I’m referring to the engine cooling fan module. And I’m pretty sure all 2015 model LR2s have the dual fan assembly. I’ve ordered a new module from AutoZone as both fans are operational, it just appears that one of the output terminals on the module is busted.
Old Jun 22, 2023 | 10:09 PM
paige-lr2's Avatar
7th Gear
Originally Posted by ThorInc
thanks for the link. I had read through this thread before posting my thread but I think it confirms my suspicion. Both of my fans are operational so I think it’s just the cooling module that needs to be replaced. I’ll have to revisit it after replacing the module. Thanks!
Sinfullslice
LR2
Oct 5, 2019 07:23 AM
samfb24
LR2
Sep 30, 2019 01:13 PM
Dayton
LR2
Jul 11, 2018 07:50 PM
Dayton
Jul 10, 2018 07:56 PM
samfb24
LR2
Jun 6, 2016 12:06 PM
