Fluid leakage underenath the engine.
Old Oct 3, 2024 | 09:50 AM
Letran's Avatar
Default Fluid leakage underenath the engine.
2012 LR2 / 6 cylinder. I don't see any leaks​​​​​​ on the ground but it seems it's coming from the rubber hose (yellow arrow). Am I correct? The backgound is the oil pan.
Thanks for any insights,
Old Oct 3, 2024 | 05:06 PM
flybd5's Avatar
What is the fluid? Engine oil? Coolant?
Old Oct 3, 2024 | 06:05 PM
Letran's Avatar
Hi flybd5, the fluid is sticky, looks like engine oil
Old Oct 3, 2024 | 07:01 PM
flybd5's Avatar
Could be the hose to the oil cooler. But a word of warning, when one hose fails, it might also be a sign that other hoses are going the same way. Check all hoses to see if they are getting soft. I had to change ALL my cooling and oil hoses on my 2008.
Old Oct 4, 2024 | 03:27 AM
Letran's Avatar
It has 147K miles, I'll check if the hoses are still pliable, otherwise I'll change it. Thanks for the reply
Old Oct 23, 2024 | 10:58 AM
Letran's Avatar
Hello flybd5 and others,
I ordered the hose to the oil cooler.
Upon installing, do I need do it after an oil change or I can do it anytime when the car is not running? I'm thinking if I pull the hose out, the engine oil might start to spill
Old Oct 23, 2024 | 11:13 AM
flybd5's Avatar
RTFM. The Service Manual is your friend. You will find the link to download it here, just search for "service manual."
Omkar Gawade
LR2
35
Aug 29, 2023 11:54 AM
Nitrolr2
LR2
Oct 28, 2021 10:56 AM
Brandon318
Feb 24, 2021 09:58 PM
maxamilione
LR2
Dec 11, 2017 03:55 PM
bballjames
Nov 28, 2015 08:39 AM
