Front driver seat does not recline
Old Jul 12, 2020 | 09:13 AM
JoaoPintoReis's Avatar
Default Front driver seat does not recline
Hello.
My Freelander 2 front driver seat will not recline, but it will angle forward.
Everyother movements are ok. The whole seat will move forward and back, up and down but just will angle forward and does not recline.
Any clues?
How can i fix this?
Thanks all
Old Jul 12, 2020 | 11:37 AM
Hello again!
I was disassembling (trying) to try to understand if any wire would be disconnected with cut or out of normal.
Everything seemed well connected.
I turned everything off and even with the sockets off, the bank's engines work.
But ... the bank continued without reclining back.
What are the yellow, orange, pink and blue sockets for?
I turned them off and the bank works the same.
I didn't find anything wrong.
Why doesn't the seat recline backwards?
Hug to everyone
Old Jul 12, 2020 | 11:39 AM
flybd5's Avatar
Originally Posted by JoaoPintoReis
Hello.
Any clues?
How can i fix this?
Thanks all
Clean the switch thoroughly with contact spray. Check to see if the connector has come loose. Otherwise you need to replace the switch, or the entire module.
Old Jul 12, 2020 | 12:46 PM
Hello.
I was just doing that.
And, with the connectors disconected, the seat was still moving. Just not the recline to back.
When you say to replace the entire module, is the board where the buttons are?
Old Jul 12, 2020 | 12:51 PM
flybd5's Avatar
Hello.
Yes. I just checked, and you can't get just the switch unless you go to a salvage yard, and even then it's best to just replace the entire module. There's one with the memory switches and one without.
https://allbrit.de/epc.cfm?PAGE=4190...CHE=EN#14C715A
I do think your best is a salvage yard. I recommend searching in car-parts.com, assuming you are in the US. Otherwise look for one in your country.
Old Jul 12, 2020 | 01:06 PM
I am In Portugal.
There are not to many Freelander 2 in these roads!!
Very very hard to find a salvage Freelander 2.
Old Jul 12, 2020 | 01:20 PM
flybd5's Avatar
Not hard at all. There are plenty of salvage yards in the UK with Freelander 2's. Google is your friend.
Old Jul 12, 2020 | 02:57 PM
But UK is RHD. Where in Portugal is LHD.
So, driver seat and passagenr seat change sides!!!
My passenger seatr does not regulates the height. And driver seat does.
Old Jul 12, 2020 | 03:29 PM
flybd5's Avatar
So ask for a LHD panel. The UK yards and dealers sell to buyers all over Europe and abroad. Besides, the part numbers for LHD and RHD are the same. Look at the diagram again.
