Front driver seat does not recline
Old Jul 16, 2020 | 04:47 AM
JoaoPintoReis's Avatar
Hello everyone.
I have already solved half the problem.
I was able to find out which connector connects the seat's recline.
I disconnected the wires and connected them the other way around. So, I was able to put the seat back in a comfortable position.
And therefore, I think I can conclude that what has broken down is the seat recline switch.
Will it be?
Old Jul 16, 2020 | 08:37 AM
flybd5's Avatar
What do you mean by this?
Old Jul 17, 2020 | 05:55 AM
Hello.
I found the right plug the controls the switch to recline.
It has two wires. One to go forward and the other one backward.
I switched positions. So, when i press the swith to go forward, in the switched position, it goes backward.
But now i need to buy a new board/switch to replace the actual one so it can work correctly both ways!
[img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABQAAAAUCAQAAAA ngNWGAAAA/0lEQVR4AYXNMSiEcRyA4cfmGHQbCZIipkuxnJgMStlMNmeyD2d wmc8+sZgxYJd9ErIZFHUyYYD7fkr6l4/rnvmtl7+KitrqV/fq2Y5eLY3Z9S48eRLe7BmVZ9qhTLhQ0algzZWQOVKSsCF8OjAn wbxDTWFDUhPK/jMr1H6HE/IqRky2DyvCefuwItwZzodVoYRiLqMkVCXrwpJ9twZ+sgfDYEFY l8wIWxZ9uFf7zkallxlJh4YrLGsKjZRx7VGHhLqwgFUN45DGdb 8MeXGpgB4ABZdeDcpZEY51A+hyLKz4S1W4MQWm3AibWtgWmk6d yISa1pSdyWTOlLXVp0+eL9D/ZPfBTNanAAAAAElFTkSuQmCC[/img]
Old Jul 17, 2020 | 08:15 AM
flybd5's Avatar
You are correct, looks like switch is bad, but have you tried cleaning it first with spray contact cleaner, or even a little rubbing alcohol spray?
Old Jul 17, 2020 | 01:21 PM
Hello
Yes, i clean the board and the switches. Did not change anything! So, 99% that the problem is there!!
Old Jul 17, 2020 | 08:34 PM
flybd5's Avatar
Agreed. The hard part will be finding a replacement switch.
Old Jul 22, 2020 | 11:40 PM
guy's Avatar
guy
hmmm, sorry I'm just reading this now.
I went through this. Not the switch in my case but a need to have the seat control module re-flashed at the dealer.
A 5 minute fix.
Old Jul 23, 2020 | 04:45 AM
A 5 minute fix.
Hello!
Really?
Re-flashed?
3 axis, 6 directions... only one direction is not working.
So, in your oppinion... it is easy to solve!
Well, i will get time to go to the dealer.
Thanks
Old Jul 23, 2020 | 06:38 AM
JUKE179r's Avatar
Reflash a seat control module on a LR2?
Old Jul 23, 2020 | 08:16 AM
I really don't know!
With time, on my holidays, i will take a deep look in the switches!!
