Front driver seat does not recline
Hello everyone.
I have already solved half the problem.
I was able to find out which connector connects the seat's recline.
I disconnected the wires and connected them the other way around. So, I was able to put the seat back in a comfortable position.
And therefore, I think I can conclude that what has broken down is the seat recline switch.
Will it be?
Will it be?
I found the right plug the controls the switch to recline.
It has two wires. One to go forward and the other one backward.
I switched positions. So, when i press the swith to go forward, in the switched position, it goes backward.
But now i need to buy a new board/switch to replace the actual one so it can work correctly both ways!
[img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABQAAAAUCAQAAAA ngNWGAAAA/0lEQVR4AYXNMSiEcRyA4cfmGHQbCZIipkuxnJgMStlMNmeyD2d wmc8+sZgxYJd9ErIZFHUyYYD7fkr6l4/rnvmtl7+KitrqV/fq2Y5eLY3Z9S48eRLe7BmVZ9qhTLhQ0algzZWQOVKSsCF8OjAn wbxDTWFDUhPK/jMr1H6HE/IqRky2DyvCefuwItwZzodVoYRiLqMkVCXrwpJ9twZ+sgfDYEFY l8wIWxZ9uFf7zkallxlJh4YrLGsKjZRx7VGHhLqwgFUN45DGdb 8MeXGpgB4ABZdeDcpZEY51A+hyLKz4S1W4MQWm3AibWtgWmk6d yISa1pSdyWTOlLXVp0+eL9D/ZPfBTNanAAAAAElFTkSuQmCC[/img]
Yes, i clean the board and the switches. Did not change anything! So, 99% that the problem is there!!
Hello!
Really?
Re-flashed?
3 axis, 6 directions... only one direction is not working.
So, in your oppinion... it is easy to solve!
Well, i will get time to go to the dealer.
Thanks
