Gaskets and seals for turbo
Old May 23, 2023 | 01:44 PM
ourx15's Avatar
Default Gaskets and seals for turbo
Hello. I am installing a new exhaust manifold and turbo. I have the manifold gasket, oil screen, exhaust gasket at catalytic converter, 4 brass crush rings and 2 gaskets for the short oil line. Wondering if I need anything else for gaskets and seals? Thanks in advance.
it’s a 2013 lr2 with the 2.0l gas engine
Old May 31, 2023 | 08:40 AM
curb-optional's Avatar
interesting: I have a 2015 LR2 - about 85k miles. My dealer recently replaced my turbo, saying it had cracked from cold/hot seasonal weather pattern. The white smoke billowing from the tailpipe and gas/fume smell in the cabin were clues something was off. Good luck with the replacement.
Old Jun 19, 2023 | 03:33 PM
ourx15's Avatar
Found all the seals I needed. Mine was smelling like exhaust in the car and could hear an exhaust leak behind motor. Took me about 10hrs to do myself. Mainly the one exhaust bolt and the flexible oil line was time consuming!! But a few beer breaks and deep breaths, I got the unit replaced. So far so good.
Old Jul 4, 2023 | 09:59 AM
alex_moon's Avatar
5th Gear
Default Syringe with fluid?
I have a 2014 LR2 HSE and am about to tackle the turbocharger/manifold replacement. I just ordered this turbocharger today: https://turbochargersdirect.com/new-...ur-100202-ftn/
Since you recently did this install and found all of the gaskets, can you tell from the photo in the link if I will need any additional gaskets? Also, any idea what the syringe with fluid is for? Thanks.
Old Jul 4, 2023 | 01:34 PM
ourx15's Avatar
You need 4 brass washers. I would get one more of those double washer things. As I am sure I replaced 4 of those. And an oil inlet filter.
Old Jul 4, 2023 | 01:38 PM
ourx15's Avatar
Not sure about the syringe and three studs and nuts? Mine did not come with those.
Old Jul 4, 2023 | 01:40 PM
ourx15's Avatar
Really good video on YouTube by Nick Vendetti. I followed his vid and it helped alot
Old Jul 5, 2023 | 07:45 AM
alex_moon's Avatar
5th Gear
ourx15 - I am having a hard time tracking down the oil inlet filter. I tried the part number on the photo you provided (1330865) but nothing comes up. Is there another part number somewhere that I'm not able to see? Thanks
Old Jul 5, 2023 | 10:06 AM
ourx15's Avatar
I just went to Land Rover dealer and asked for one. They have them in stock as they replace the manifold often.
Old Jul 5, 2023 | 10:24 PM
alex_moon's Avatar
5th Gear
Thanks much!
Austing
Oct 25, 2022 08:15 PM
Charlie_V
Jun 30, 2016 11:00 PM
LR03NJ
Mar 8, 2016 04:37 PM
04duxlr
Jul 3, 2013 11:02 AM
Robwsup
Feb 16, 2010 05:06 PM
