HDC System Fault problem
Old Feb 23, 2021 | 09:10 PM
Bbg's Avatar
Bbg
Default HDC System Fault problem
Hi Fellas ,
i have 2012 land rover hr2 , i love my car but fix the car is unnecessary expensive in that case first of all i try my best first then go to mechanic by the way lots of mechanic dont understand this car's problems anyways
My problem is ' HDC system fault ' it comes in rainy weather while i drive , car dashboard and gps systen reset itself go and back again every 10-15 min but noting change on my drive and no ayn dash codes or lights
i thought that i have to change my battery and mamke couple hundred miles with that but before this , do you guys any recommendation.
thanks a lot
BR
Old Feb 23, 2021 | 10:51 PM
flybd5's Avatar
Originally Posted by Bbg
Hi Fellas ,
i have 2012 land rover hr2 , i love my car but fix the car is unnecessary expensive in that case first of all i try my best first then go to mechanic by the way lots of mechanic dont understand this car's problems anyways My problem is ' HDC system fault ' it comes in rainy weather while i drive , car dashboard and gps systen reset itself go and back again every 10-15 min but noting change on my drive and no ayn dash codes or lights i thought that i have to change my battery and mamke couple hundred miles with that but before this , do you guys any recommendation.
thanks a lot
BR
Have you noticed water in the cabin when it rains, maybe in the area behind and under the glove compartment, but anywhere else as well?
Old Feb 24, 2021 | 12:34 PM
Bbg's Avatar
Bbg
Yes after you said i looked it up everything fine i could t understand noting wrong for now but you know it ll getting worst i think thanks anyway
Old Feb 24, 2021 | 12:41 PM
flybd5's Avatar
If it happens when it is raining it means water is getting into something it shouldn't be.
Old Feb 24, 2021 | 04:06 PM
ThorInc's Avatar
Trying to follow the original post.............so,have you replaced the battery with a new one? Also, have you checked or added a new or second ground/earth to the starter motor?
Old Feb 24, 2021 | 04:09 PM
flybd5's Avatar
Not sure how you get from HDC system fault and electrical issues to a new ground for the starter motor.
Old Feb 24, 2021 | 04:12 PM
ThorInc's Avatar
https://www.freel2.com/forum/topic16...ight=hdc+fault
And the search:
https://www.freel2.com/forum/search....&search_time=0
Maybe I should have added a new battery earth and left it there
Old Feb 26, 2021 | 06:53 AM
ThorInc's Avatar
https://www.freel2.com/forum/topic36592.html
Old Feb 26, 2021 | 10:08 AM
flybd5's Avatar
Originally Posted by ThorInc
Ok, but the thread doesn't say that solved the problem... From my experience it's quite hard to screw up an earth connection. Usually it just means the connection points have to be rubbed with a wire brush.
Old Feb 26, 2021 | 08:08 PM
Bbg's Avatar
Bbg
Thanks for all answers i ll try to do on this weekend
thanks again
Disco V
Feb 5, 2021 11:36 AM
bebushka
Feb 18, 2020 11:02 AM
Frank Swenson
Dec 28, 2019 04:29 PM
carlitonsky
Mar 22, 2009 04:16 PM
