LR2 upper top coolant hose replacement
Old Mar 1, 2021 | 08:15 PM
Hamza89's Avatar
Default LR2 upper top coolant hose replacement
Hi Members ,
Is it possible to replace the upper top coolant hose without removing the intake manifold ?
Hose is attached in the picture .
Thanks
Old Mar 1, 2021 | 09:58 PM
flybd5's Avatar
No, as you can see from this diagram. You can't get to it without removing the intake manifold, there's not sufficient clearance.
Old Mar 1, 2021 | 10:36 PM
Hamza89's Avatar
thanks a lot , the intake manifold gaskets were replaced less than 2 months ago , can I re-use them ?
Old Mar 1, 2021 | 10:42 PM
flybd5's Avatar
You're supposed to discard them when you r&r the manifold, but if they are still in new condition that's up to you. A new set runs $30 on eBay.
While you are changing that one hose, you should also replace the thermostat if you haven't done so in a while, and check all the other hoses as well.
Old Mar 1, 2021 | 10:43 PM
Hamza89's Avatar
always appreciating your constant support , thank you very much .
INTER911
LR2
Feb 5, 2020 09:28 AM
Martimouse55
LR2
Jan 29, 2019 12:13 PM
Inkstaind1
LR2
Jan 28, 2019 10:07 AM
01disco2
Sep 10, 2010 02:31 PM
werldcup
Mar 14, 2007 05:05 PM
