Help
Old Sep 23, 2024 | 11:53 PM
  #31
stephdoerfstep's Avatar
OldKarz,
Is their anything that you know I could do to check to see if it would be a bad sensor ? Hoping you do before I have to (hopefully don't have to), take it to shop as the other guys were saying?
Thanks for the help!!!
Old Sep 24, 2024 | 08:25 PM
  #32
flybd5's Avatar
Originally Posted by OldKarz
Your ECT is way to high. If the engine is compensating for a bad Sensor you could get the misfires as it runs too lean for a cold engine.
Engine Coolant Temperature???
Old Sep 25, 2024 | 07:14 AM
  #33
OldKarz's Avatar
Just a clarification: The coolant temperature may be correct if it is reading Fahrenheit and the engine had not been running too long. If it is Celsius, which I assumed, it is too high.
However a bad sensor can still be causing your problems. For example if your O2 reading is incorrect it will fuel to correct to the bad reading. This could cause lean or rich running. You could disconnect the O2 and see if it runs better. It will default to a programmed value and, of course, will throw a code.
Old Sep 25, 2024 | 02:57 PM
  #34
okay1!To disconnect the O2 ........I WOULD GO ABOUT DOING THAT HOW??
Old Sep 25, 2024 | 05:52 PM
  #35
OldKarz's Avatar
Follow the wire from the pre-cat O2 sensor to its connector. Disconnect that. O2 sensors can get lazy and respond very slowly or incorrectly which can throw off fueling.
Old Sep 25, 2024 | 09:01 PM
  #36
flybd5's Avatar
There are four O2 sensors in the LR2. The upstream ones connect at the top rear of the engine. The downstream ones connect under the chassis.
Old Sep 25, 2024 | 11:49 PM
  #37
LR2driver's Avatar
Would it be easier to check if the fuel trims are out of range to get an indication if an O2 sensor is faulty?
Old Sep 26, 2024 | 08:29 AM
  #38
OldKarz's Avatar
Fuel trims can be deceptive. An overly rich engine, that is missing, will actually be logged as running lean since a lot of unburnt air is being pumped through, which is seen as needing more fuel!!
Old Sep 26, 2024 | 11:51 AM
  #39
p_gill's Avatar
When my LR2 purge valve failed I got very rough running and codes like you are having.
The Valve is connected directly to the intake manifold and to the gas tank.
Its on the list
Less common repairs
I. Starter motor - typically fails at 100,000 miles or 10 years
II. Blower Resistor
III. Front Brake calipers refurbished
IV. Loose bolt on alternator pulley
V. Overdrive clutch pulley Alternator
VI. Overdrive clutch pulley READ drive (Serpentine Belt)
VII. BLUETOOTH phone module (bypass with a fiberoptic loop if you don't use it)
VIII. PurgeValve for Fuel Vapor Recovery
2008 LR2 3.2 items completed
Maintenance 1,2,3,4,5,6,7,8,9,11
Typical repairs A, B, C, D, E, G, I, K
Less Common Repairs I,III,V,VI,VII,VIII
The purge valve can be seen in this picture
If you remove the plastic pipe and then cap the port then the purge valve will be defeated and you can see if the engine starts and runs.
If it does then you will need a new purge valve.
Someone on here will know that part number
Note: I had very similar symptoms (possibly identical) to what you are having but I knew about the purge valve and I had one on the shelf so I replaced it.
Thanks
Paul
Old Sep 26, 2024 | 11:55 AM
  #40
p_gill's Avatar
A link with more information
https://www.matthewsvolvosite.com/fo...it=purge+valve
