help changing 2008 lr2 alternator
Old Dec 9, 2013 | 08:52 PM
crackofdawn's Avatar
Default help changing 2008 lr2 alternator
Can I get a couple step by step instructions to get to the alternator? I have the dreaded coolant leak. That is a different issue to be resolved.
But can someone please direct me to a post with how to get to the alternator. I have the alternator, and want to get moving, but I don't want to tear into this just by ripping everything out that I "think" needs removed.
I assume I have to remove the air intake, but that is where I need some guidance. What all do I have to remove, loosen, etc to get the intake out of the way.
Much appreciated if anyone can assist.
Old Dec 11, 2013 | 11:02 PM
Ok, basic questions to removing the intake... do you have to remove the fuel rail to get the intake up past it? In trying to get the intake off, I can not get it forward enough because of the radiator and fan... and I can not bring it straight up because of the fuel rail. Just looking for general guidance to get this damn thing off. Anyone with any details please.
Old Dec 30, 2013 | 08:48 AM
Steph Simmonds Myers's Avatar
Exclamation 2008 land Rover LR2 Alternator change
Hey man,
I am having the same issue here! I need to change it over but I cannot find any info on it. keep in touch and let me know if you find out anything. And I can do the same
-Stephanie
Old Dec 30, 2013 | 09:14 AM
Removal of Intake Plenum.. so far this is what I have
  1. Remove the Air Cleaner (ACL) outlet pipe.
  1. Disconnect the electrical connectors.
    1. Remove the fuel supply manifold.
    1. Detach the engine wiring harness and position to one side.
    1. Disconnect the vacuum supply hoses from the intake manifold by squeezing the tabs, twisting the hoses and pulling away from the intake manifold.
    1. Disconnect the brake booster vacuum line from the intake manifold.
      1. Remove the fuel charging wiring harness.
      2. Remove the accessory drive belt.
      3. Remove the generator bolts. Position the generator to one side.
      1. Remove the intake manifold.
        1. Remove the intake manifold gasket. Discard the gasket.
        Installation
        1. Install a new intake manifold gasket.
        1. To install, reverse removal procedure.
        Source: I need to replace the intake plenum gasket
        Old Jan 9, 2014 | 08:32 AM
        aaron svendsen's Avatar
          • Throttle Position (TP) sensor.
          • Idle Air Control (IAC) .
          • Engine control sensor wiring.
          • Disconnect the quick-release coupling and pull out the line.
          • Remove the seven bolts and two nuts.
        Installation
        I had the dreaded coolant leak as well. I bought a new quick connector and hose from the land rover stealer and replaced it. That fixed the leak, but now my alternator light is intermittently coming on- so I may need to replace the alternator soon. I've replaced alternators before on American cars, but the LR2 looks a bit tricky. Could you possibly email me your instructions with the pictures you have? For some reason I cant view the pictures.. Thanks in advance.
        Old Aug 24, 2019 | 07:44 AM
        Toybreaker's Avatar
        Pictures don’t show up, this also does not address the issues I am having with clearing the coolant pipe that is sticking out of the head.... hoping a thread reply notification will get show traction here
        Old Aug 26, 2019 | 04:00 PM
        p_gill's Avatar
        https://www.freel2.com/forum/topic32245.html
        crackofnoon
        LR2
        Oct 28, 2018 01:55 PM
        twin6
        Jan 26, 2017 03:22 PM
        chubbs878
        Dec 24, 2015 08:44 AM
        searanch
        Nov 22, 2011 05:54 PM
        joeking
        Freelander
        Mar 3, 2011 10:33 AM
