HVAC / Temperature Control
Old Jan 13, 2017 | 06:54 AM
bosalls5's Avatar
Default HVAC / Temperature Control
2009 LR2: The issues were my HVAC was stuck on defrost and wouldn't shift to front outlets or feet while not being able to regulate temperature (hot). I picked up a used HVAC control panel and I made some head way. The new / used panel worked but the drivers side would not modulate temperature while the passenger side operated normally. The (3) directional settings worked, heated seats and windshield all worked. Anyway to test a panel? Go for a new panel? How common is this HVAC issue?
Thanks Bob
Old Jan 23, 2017 | 10:59 AM
bosalls5's Avatar
Land Rover found a short in the power feed (inside the dash area) to the motor that controls the mixing door in the HVAC plenum. (4) hours labor to fine the short and replace the section of wire. All else check out ok
Old Jan 23, 2017 | 11:01 AM
bosalls5's Avatar
Land Rover found a short in the power feed to the motor that controls a mixing door in the HVAC plenum. (4) hours labor to open the dash and replace a wire. All else checked out ok.
outdoor7or24
Nov 11, 2013 01:06 PM
dgilson4
Oct 25, 2011 11:26 AM
souljad9
Apr 30, 2011 10:16 AM
XCSC
Aug 5, 2009 02:26 PM
Fyko
Defender
Jul 6, 2007 06:57 PM
