HVAC Control lights
Old Jan 21, 2009 | 07:56 AM
souljad9's Avatar
Default HVAC Control lights
I searched, but haven't been able to find a definitive answer. Most posts are about the lcd screen, or the red/blue temp controls, but my question is:
Because mine don't, and at night, I keep hitting the wrong button while fumbling around
Old Jan 21, 2009 | 04:54 PM
Default RE: HVAC Control lights
Set the auto climate control while it is daylight and forget it.
But if you do want to see the controls you will need to replace the bulbs.
Old Jan 21, 2009 | 08:17 PM
unimoged's Avatar
Check this listing for the HVAC control module:
http://cgi.ebay.com/ebaymotors/99-00...mZ190279604754
It is $ 38 and it comes with a 90 day warranty from LKQ
I would replace it.
Old Jan 21, 2009 | 09:02 PM
Night Train's Avatar
can you buy just the bulbs - AB maybe????? I never noticed till I read this but mine don't light either. [sm=smiley13.gif]
Robert
Old Jan 21, 2009 | 09:08 PM
ORIGINAL: Night Train
Robert
Take out the old burnt out bulbs and then take them to Radio Shack, NAPA, AutoZone and match up with what they have on the shelf.
Old Jan 22, 2009 | 07:16 AM
unimoged's Avatar
If I recall right, they have LEDs soldered to the circuit board. The problem is not the LEDs, they usually have a very low failure rate. The problem is in a soldering joint that is cracked. Replacing the module is a plug and play.
Old Jan 22, 2009 | 06:19 PM
souljad9's Avatar
I pulled it and opened it up. Ordered a newbulb from AB.
Old Jan 22, 2009 | 06:27 PM
unimoged's Avatar
souljad9, thanks for sharing this easy fix. What type of bulb for future reference.
Old Jan 27, 2009 | 07:39 AM
souljad9's Avatar
http://www.roverparts.com/Parts/JWH100070G.cfm
Same bulb for the control buttons, and also for the temp control rockers.
Old Apr 30, 2011 | 10:16 AM
rmetexas's Avatar
How did you access the bulbs? Does the panel pop out in front?
outdoor7or24
Nov 11, 2013 01:06 PM
XCSC
Aug 5, 2009 02:26 PM
ScottinNJ
Jul 9, 2007 08:19 AM
alpinab7
Sep 29, 2006 03:11 AM
jons1998RRHSE
Sep 11, 2006 03:50 PM
