Key Fobs
Hello, I have a 2011 Freelander 2. I recently lost a key and am looking to replace. Any one have a recommendation on where I can buy replacement fobs? Also I have the Autel AP200, can I use that to program the keys? Is it a reliable way to do it? Meaning they won't fail and leave me stranded unable to get into the car?
Sometimes it pays to complain, I learned something!
ThorInc is correct, you can't just add a fob. You have to reprogram all the fobs in one session, up to three.
I've used these several times, they're cheap...
The last one lasted less than a year, failure mode is always the remote stops working, presumably due to bad battery. I've never had any key fail to start the car (doesn't need the battery when it's in the dock).
The AP200 usually takes a few tries to program it, just keep trying until the new key doesn't eject itself from the dock.
You will not brick your original key... you have to insert a valid key to start the process, that will remain valid regardless of what happens with the new key.
