Key Still Detected & Wiper Control Issues
Old May 8, 2020 | 09:05 PM
Rick Nelson's Avatar
4wd High
Default Key Still Detected & Wiper Control Issues
Figured i'd try to include a few items specifically here and see if there's any helpful advice from the community.
2008 LR2 SE
(1) When I remove the key fob from the slot, 90% of the time the radio will stay on and occasionally the message centre will display that the key is still detected. If I quickly insert and remove it again then it shuts off properly but this is annoying and will prevent me from locking the doors with the fob if its still "detecting" the key inserted.
(2) My front windshield washer fluid doesn't seem to operate in the manner the operating manual describes how it should. If i depress the "Thumb button" at the very tip of the lever (Which the image on it indicates front washer fluid) nothing happens, and if I pull the lever towards me (Which the image indicates rear windshield wiper/fluid) the FRONT washer fluid activates, but no wiper (either front or back).
It would almost appear as if the wiring was backwards for the wipers the way they function from how theyre allegedly supposed to, also, my rear wiper and washer fluid do not work at all. The fuse is fine so suspecting the motor to be gone...but would that also affect the rear washer fluid from not working?
Any tips or advice would be greatly appreciated, tried to upload pics but forum doesnt seem to be compatible.
Old May 8, 2020 | 09:20 PM
flybd5's Avatar
2008 LR2 SE
My first gut instinct would be to grab a bottle of good spray electronic contact cleaner and apply to anything that might look to be a plug, switch or contact. It sounds like there's some unwanted gunk in there.
peterdemski
Apr 21, 2015 10:52 AM
A5scott
Sep 9, 2011 10:35 PM
junior496
Jan 26, 2011 05:28 PM
hilltoppersx
Sep 22, 2010 07:44 PM
wildhorses
Oct 18, 2005 05:29 AM
