Land Rover LR2
Old Sep 13, 2021 | 12:58 PM
Juju4's Avatar
Default Land Rover LR2
I have a Land Rover 2008 LR2 it’s overheating now but no coolant leaks only when I remove the coolant cap? Do you know what the problem might be?
Old Sep 13, 2021 | 04:00 PM
flybd5's Avatar
The service manual indicates the following possibilities when the engine overheats:
  • Engine coolant (level/condition)
  • Thermostat
  • Fan motor
  • Fan motor fuses and/or circuits
  • ECT sensor
  • Engine control module (ECM)
  • Fan speed module
If there is sufficient coolant in the system and the radiator fan runs when the engine gets hot, it's likely the thermostat, but it could be other things.
Old Sep 13, 2021 | 06:28 PM
Juju4's Avatar
Default Land rover
  • Thermostat
  • Fan motor
  • ECT sensor
  • Fan speed module
when it overheated no coolant was leaking. When I removed the cap from coolant resivour it started leaking coolant behind the engine couldn’t see where. Could it be coolant pump?
Old Sep 13, 2021 | 06:38 PM
flybd5's Avatar
It could be any of many things. If you don't have at least some detailed pics, we can't help you. Are you capable of doing mechanic work on your engine?
Jeanne Anthony
LR2
Feb 14, 2020 09:23 AM
Newlr2guy
LR2
Jun 29, 2019 08:29 AM
Sing
LR2
Mar 21, 2019 07:26 PM
roverreitzel7
LR2
Feb 27, 2013 09:51 AM
scarrittjd
LR2
Dec 5, 2007 05:42 PM
