LR2 2011 3.2 hard to start when warm
Old Dec 11, 2022 | 10:28 AM
Hamza89's Avatar
Originally Posted by flybd5
Look at the other messages. As I said, put a new MAF sensor in there first. Then look for other possible causes if the problem is still there.
Ok Ill do that , I will replace the spark plugs as well to finish all the basic service required.
Btw where do you get your part numbers from , there was a website that had an awesome EPC now its gone .
any links for a good EPC ?
Old Dec 11, 2022 | 10:30 AM
flybd5's Avatar
https://new.lrcat.com/#!/12111
Old Dec 11, 2022 | 10:32 AM
Hamza89's Avatar
Thanks a lot .
Old Apr 10, 2023 | 06:37 PM
Hamza89's Avatar
Update : if you were following my other post you will find that i replaced almost the whole coolong system on the car , during this job i found many wires under the intake that were exposed, i fixed all these wires and i found that the maf sensor was not pushed correctly inside the air cleaner box , I lubricated the O ring and pushed it inside all the way , after doing that the issue was completely fixed , most probably it was the MAF .
abfoster
Jun 25, 2022 09:14 AM
devicespy
LR2
Mar 14, 2008 04:31 PM
ronx
Other
May 15, 2007 11:08 AM
05LandRover
Freelander
Dec 18, 2006 04:17 AM
