LR2 it cranks but will not start
Old Nov 20, 2019 | 08:41 AM
p_gill's Avatar
I agree fuel is the next place to look
The Fuel system on the LR2 is returnless and the pump is run to maintain pressure (i.e. Duty Cycle or PWM if you prefer)
the ECU controls the pump based on the fuel rail pressure sensor.
If the sensor has failed that may cause your failure to start.
https://www.matthewsvolvosite.com/fo...p?f=26&t=88793
Or it could be the in tank fuel pump
https://www.matthewsvolvosite.com/fo...p?f=10&t=88941
Thanks
Paul
Old Nov 20, 2019 | 01:03 PM
p_gill's Avatar
Note: if you decide to try the following you do so at your own risk.
Here is what I would do if my LR2 wouldn't start like you describe
1. Put some gas in the tank (2 or 3 gallons should be enough if you are half full to start) so that the tank is more then half full (if the transfer pump is broken you may be pumping air and it will never start if you are)
2. Try starting one more time
3. Remove the MAF and spry a combustible liquid for about 10 seconds (carburetor cleaner would work) in the intake tube
4. leave the MAF removed and disconnected (the open hole will allow air to enter the engine even if the air filter is clogged)
5. Try starting the engine
If the ignition system is working it should start but it may not continue to run depending on the fuel pump and fuel pressure sending unit condition
Note: if you've never starter a carburated car with a spray from an combustible liquid then you should get help from a friend that has before you try doing this
Good Luck
Paul
Old Nov 21, 2019 | 11:03 PM
jtray08LR2's Avatar
Thanks
Paul
Thanks Paul, I ordered this Fuel Rail Pressure sensor never even thought of that but I had a similar issue on another car and it seems easy to access. I am going to try this out and report back before getting into the fuel tank. Thanks again for all the help with this, will report back.
Old Nov 21, 2019 | 11:17 PM
jtray08LR2's Avatar
Good Luck
Paul
I have kept a boat running with carb spray, but never fired off a vehicle. So do I remove the MAF and spray into its spot on the intake tube then try to fire it or is it best to have some one spray while another is trying to start the ignition? I bought a fuel rail sensor that was inexpensive, so I am going to see how this will work
Old Nov 22, 2019 | 08:26 AM
p_gill's Avatar
Either way should be fine.
Let us know what works.
Good Luck
Paul
Old Dec 1, 2019 | 09:31 PM
jtray08LR2's Avatar
So I am reporting back, I have replaced the fuel rail pressure sensor and I am getting the same result. My next endeavor is the tank fuel pump replacement. When I replaced the pressure sensor, fuel just leaked out of the rail line roughly 200 milliliters. Is this any indication as to where the problem may lie? Keep in mind this vehicle has not run in about a month or so.
Old Dec 1, 2019 | 10:04 PM
jtray08LR2's Avatar
Good Luck
Paul
So after replacing the pressure sensor, I tried to start with carb spray and it DID fire off but just briefly, it didn't run for more than 2 seconds but I am happy to see the progress regardless. With that being said, is there anyway to tell if it is the pump or sending unit? With the holidays purchasing these parts are taking longer than normal and I am also trying to minimize cost (but who isn't) if possible? Thanks for all the help with this, I will always continue to support this place
Old Dec 2, 2019 | 04:22 PM
p_gill's Avatar
That is great news
I would look at the electric connections for the fuel system
The fuse that runs the fuel pump module is located in front to the passengers feet
Fuse 22
the fuel pump module should draw about 5 amps
For my LR2 I noticed that it won't start until the fuel pump turns on and is drawing about 5 amps
I bought a fuse buddy meter to check it
More info about the fuel pump and its wiring can be found here
let me know if you can't download the PDF from Freel2 and I will post it here as well
https://www.freel2.com/forum/topic34749.html
Take care
Paul
Old Dec 11, 2019 | 12:25 AM
jtray08LR2's Avatar
That is great news
Fuse 22
Take care
Paul
Thanks Paul, so I checked the fuel pump fuse and it is good. I do not have the fuse buddy so I will need to get one of those. However I removed the back seat to access the fuel pump and this is what I found, I would assume this could be affecting the pump or caused it to overwork and burn up? This looks difficult to access, there is framing around it and looks like it requires most of the trunk and back seat removed. Any thoughts?
Old Dec 13, 2019 | 04:20 PM
p_gill's Avatar
File Type: pdf
