LR2 Headlamps going out
Old Sep 24, 2025 | 05:08 PM
Leebop777's Avatar
Lightbulb LR2 Headlamps going out
I have a 2013 LR2. Recently, both headlamps either in normal or high beam go out at the same time. Sometimes 5 min into a trip or maybe 30 min or sometime not at all. Very sporadic. Even if set to auto. I have been driving with the front foglamps on fulltime so if regular beam goes out, I'm not in the dark. No issues with the lamps themselves and I could not find any issues with fuses. Obviously, something is loose somewhere so any advice where to start and what to look for? Driving me crazy. Thank in advance.
Old Sep 24, 2025 | 06:45 PM
LR2driver's Avatar
There is a fuse and a relay inside the junction box in the engine compartment which are for the headlights. It's possible that some minor corrosion is causing either one to open the circuit after it warms up.
Fuses are so inexpensive and easy to change that I would just replace with a new one to eliminate it without any doubt. And you can swap out the relay with a similar one adjacent to it and see if the problem goes away. But do one at a time, so if the problem is solved then at least you know which one it was, fuse or relay.
Hopefully these simple steps will solve the problem before you have to dig deeper.
Colorado Car
LR2
21
Nov 5, 2021 12:59 PM
Justin Ruiz
LR2
Jul 16, 2021 07:03 AM
roverreitzel7
LR2
Feb 27, 2013 09:51 AM
05LandRover
Freelander
Dec 18, 2006 04:17 AM
