Oil filter access 2013 LR2
Old Sep 26, 2025 | 06:45 PM
Kevin Chambers's Avatar
Default Oil filter access 2013 LR2
Hello - I would like to start changing my own oil on my 2013 LR2. I have about 47K on the vehicle. I purchased the proprietary oil and filter, I removed the panel under the engine and located the oil drain plug. I also located the oil filter - at the forward end of the engine above a thick hose. It is not even visible from the top of the engine, and it doesn't look like it would fit between the thick hose and frame. Does anybody have any experience they can share with this. Thank-You!
Old Sep 26, 2025 | 07:14 PM
flybd5's Avatar
I have zero experience with 2013 and newer LR2s. If they are anything like 2008-2012 you'll need a 27mm socket to remove the oil filter housing cover, then remove the filter and gasket, and replace them with new ones. Then fit the cover back on. You do this after draining the oil from the sump and replacing the drain plug.
Old Sep 26, 2025 | 11:46 PM
LR2driver's Avatar
Originally Posted by Kevin Chambers
... I also located the oil filter - at the forward end of the engine above a thick hose. It is not even visible from the top of the engine, and it doesn't look like it would fit between the thick hose and frame. Does anybody have any experience they can share with this. Thank-You!
Pulling that oil filter housing out is a challenge on my 08. I make some room by lifting up the power steering fluid bottle off its bracket and moving it to the right side. Then removing the top screw holding the window washer fluid bottle and moving it to the left. Even with this additional wiggle room, it's a PITA.
On my next oil change, I'm going to try removing the headlamp assembly (actually quite easy) as that may allow me to reach straight in from the front instead of the top.
Old Sep 27, 2025 | 12:06 PM
flybd5's Avatar
Why remove the entire housing? Even the Valvoline oil change people know how to just take out the cover and the filter. ??
Old Sep 27, 2025 | 12:19 PM
LR2driver's Avatar
Yep, I meant to say cover.
I prefer the older style spin-on filters.
Old Sep 27, 2025 | 12:27 PM
flybd5's Avatar
I prefer German beer too, but it's pain to find it around here. 🤣🤣🤣
Old Sep 28, 2025 | 07:44 AM
merlinj79's Avatar
The cartridge filter isn't that bad, I bought the big socket and use a swivel and 1/2" extensions. Cover spins right off and back on.
Yes, you should move the PS res, it just slides out of it's bracket, no fasteners.
Be sure and remember to remove the old o-ring on the cover... it gets flattened and can be hard to see. If you miss it and put the new o-ring on top, it will leak, a lot. Ask me how I know.
Farman mohammed
LR2
Sep 28, 2025 07:46 AM
LR2driver
LR2
23
Jul 4, 2021 04:22 PM
Mark Sims
LR2
Mar 11, 2016 05:34 PM
dcous13
LR2
May 29, 2013 04:46 AM
merlinj79
LR2
Oct 1, 2012 02:38 PM
