LR2 heater problem
Old Oct 19, 2021 | 12:00 AM
Michael20*'s Avatar
6th Gear
Default LR2 heater problem
Hi, i have a 2010 freelander 2 td4 se, and the heater doesn't get hot even if you shift it to warm, and the selector that select where the air must blow doesn't select. The lights is shining at the selection where it must blow but stay on only the front vents.
What can be wrong.
Old Oct 19, 2021 | 11:09 AM
flybd5's Avatar
What can be wrong.
That sounds like the climate control panel has gone south. Sometimes a good cleaning with contact cleaner will fix it, but other times you have to buy a replacement.
Old Nov 3, 2021 | 01:23 PM
bidoulatt's Avatar
Banned
My guess is (based off your description and some knowledge but mainly guessing): -The car could have problems with the temp sensor. It could give incorrect information to both the gauge and the fans letting it think that it's overheated. -The thermostat can be faulty. Maybe getting stuck in closed position for a while letting the engine get hot.
Old Nov 3, 2021 | 01:24 PM
flybd5's Avatar
Hmm. If the thermostat was broken I would think it would show up on the temperature gauge...
Old Nov 3, 2021 | 09:58 PM
Michael20*'s Avatar
6th Gear
Thanks for all the feedback.
I went through the fusebox in engine bay and discovered a relay that was busted. After replacing it the heater worked perfectly.
Old Nov 4, 2021 | 09:13 AM
flybd5's Avatar
Sweet!
Old Feb 28, 2024 | 08:51 AM
defender dav's Avatar
hi there what relay controlled heater cheers
kylltyme1
Dec 25, 2019 10:57 AM
ccriderbmg
May 21, 2019 12:05 AM
LR03NJ
Oct 19, 2017 06:04 PM
redrover75
Dec 3, 2016 10:00 AM
sorusty
Dec 5, 2011 03:29 PM
